Next, you should be able to download it using your Android box. Give that a try, download it from your Android box and see if it will extract. Also, copy it from your Android box and test it again on your computer.
Unable to un zip atvXperience v2A/2B
Originally posted by philcanaries View Post
Next, you should be able to download it using your Android box. Give that a try, download it from your Android box and see if it will extract. Also, copy it from your Android box and test it again on your computer.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by philcanaries View PostIve downloaded it through Chrome on the Nvidia Shield and passed it to my PC with Sendanywhere and its stil saying its an unknown format or damaged !!
Would it be possible for the atvXperience-v2B rar to be extracted then sent without the rar or does it not work like that?
Yes everything is checked to allow in security
I'm gonna take a box down to work tomorrow and try it on my PC there, fingers crossed!Last edited by philcanaries; 06 June 2018, 19:51.
Hi there
I did not resolve the issue and had a friend un zip it and send it to me, stupidly I burned the image and it got all the way through to the very end and said there were errors so plugged the box into the TV and only have a black screen lol! bricked I think
Would I be able to fix this box at all? its a W95Amlogic S905W 2.4GHz WiFi Android 7.1 2GB DDR3 + 16GB eMMC
TIA
TIA
There are currently 1710 users online. 0 members and 1710 guests.
