Forum is under some work, so some instability is expected.
Hello guys, i have a problem with my dad his 10g2. The rom that was on the tablet was 1.4 from finless.
But it tooks 10min for loading to the home screen.
I decided for flashing it to 1.5c. this was succesfull bit then i read in the discription that you must erase idb en install the loader to. So i did this again.
Now it wont boot anymore. And when i put the rom in mask rom mode it wont erase idb and test device fails also.
Even when i take other usb and cables or take the other flashtool with original rom.
Is this tablet fully bricked or have i a little chance for recover it.
it's been so long since i have messed with one of these , try the other flash tool and use the update .img from the arnovatech site . as long as you get the green light when you connect the device you should be good . and buddy I have two 10g2's at home .if you cannot get it working let me know I will send you one of mine to give to your dad ok .no charge you can have it
freaktab art developer if you like my work please buy me a pepsi
dug my g2 out the drawer started it up finless bob 1.5,,sweet, rebooted after play store updates, but screen just white now? reset for 15 seconds not helping, neither is power and volume up.as soon as i put power into device or turn it on normally straight to white screen, no logo or nothing... is that it dead now?
edit: just remembered you have to crack it open and disconnect the screen cables and reconnect...sorted
