I found a 3rd party app that does the same job as 'status' in 'about device' and more: https://play.google.com/store/apps/d...ctricsheep.asi
Arnova 10 G2 Custom ROM by Finless Version 1.5
Originally posted by aturner View PostHi Bob,
Yet another great ROM, just one issue for me. I am now unable to connect from laptop to tablet via usb cable. My vista just doesn't seem to find the driver. Any suggestions.
Regards
Sent from my SK17i using TapatalkPlease consider donating to purchase tablets for Finless Bob to continue his work. This will help in the creation of custom roms and build an even stronger development base for our community. Thank you for you support!
</form>
Originally posted by Damo View PostWhen you connect it pull down the status bar at the top on your tablet screen and that will reveal options to turn on USB, so you can transfer files etc
Puzzled.
Regards
At that stage click the USB connected and this should pop up another screen to turn on USB mode. Strange. Try going into settings and try changing the USB debugging settings
</form>
Originally posted by Damo View PostAt that stage click the USB connected and this should pop up another screen to turn on USB mode. Strange. Try going into settings and try changing the USB debugging settings
Originally posted by aturner View PostYep, turning on USB mode did the trick, not had to use this previously. Your a star!!
Now have some fun on your tab
</form>
Just flashed mine this morning.
The new ROM is great! I rebooted twice after flashing it.
When I ran the AppInjector - I got a few errors with some of the Google Apps - "Google Play has stopped working". When I clicked "Force Close", the App Injector kept running. It happened a few times.
When it finished, no apps seemed to be installed.
I rebooted and they were all there. So, it worked fine, despite the error messages.
I also get a few force closes in the settings menu. Nothing major.
Thanks to all who worked on this!
Progress this AM. The settings stuff will be fixed! It was not Miklaus' fault it was mine. SOmething I removed in debloat caused his settings.apk to have those 2 issues.
As for the force close on gplay, again Google made some updates so I will fixing those as well.
Originally posted by merculiv View PostI just updated my flash player in market and 11 works perfectly!
Thanks for this great ROM Bob and team! Its the best out there for the Arnova 10G2! : )if you love my work please buy a coffee
<form action="https://www.paypal.com/cgi-bin/webscr" method="post">https://www.paypalobjects.com/en_GB/i/scr/pixel.gif
</form>
I will be releasing a REV B today to solve some of the issues that poped up in settings.apk as well as fix some more app injector google apps that have changed......
The STUPID phone.apk that I removed from the ROM was causing all the issues. It simply cannot be removed EVEN IF you inject it back later with App Injector. It seems that some databases are not being setup on first boot if Phone.apk is not there.
So we now see why some things are left in the ROM by the manufacturer even though we think there is no use for them!!! Lesson learned...
All the testing I did, I still missed some stuff
Anyway Rev B will be out soon.
Originally posted by Finless View PostI will be releasing a REV B today to solve some of the issues that poped up in settings.apk as well as fix some more app injector google apps that have changed......
</form>
Originally posted by jamieb158 View PostI have had no issues at all. Install was flawless, runs sweet as a nut and gplay is fine. What do you think go with rev b or leave it?
Sent from my AN10G2 using Tapatalk
Update 1.5
Originally posted by Finless View PostYou missed something somhow. I have on skype watched 4 people now follow my procedure. It worked for them no issues.
Daman used Windows 8 to copy the files and it did not work. So you did not "really" get package.zip onto your root /sdcard. Sorry but you did not or it was not copied right.
REMEMBER THIS! REBOOT after flash! Your SD Card will be the internal one and on a reboot anything you put in there will be gone on reboot!
I think Daman did this as well without rebooting after the flash!
Try again please.
Now for my Onda Vi40, they just released another rom for it and it just keeps getting better and better with less 4.0ICS bugs with each release! My G2 is fast and the more apps written for 4.0 it will be improved and cleaner. I cannot wait for you to get one and get me a Finless rom for it!! If I could put the 1.5a rom on that tablet, Apple would be running for cover!! I have an iPhone4 and use it a lot less now and I was never an Android believer until now! Keep up the good work and GREAT JOB! to all the contributors for this magnificent ROM!
PS>>>> Get busy on the OndaVi40, you will not be disappointed. I know you cannot wait to get your fingers into Android 4.0 Ice Cream Sandwich to see how it ticks! LOL
thanks again to all.
Jake you pretty excited with your Ics on your onda tablet it is great to use. My cube tablet is having loads of updates now from about 7 developers and it keeps getting better. I'm loving the Ics!
Sorry naughty me going off topic
</form>
There are currently 709 users online. 14 members and 695 guests.
Most users ever online was 7,737 at 14:33 on 01-16-2020.
