Arnova 10 G2 Custom ROM by Finless Version 1.5
Originally posted by Finless View PostWhile I frown on people that return tablets they messed up, flashing a ROM is a fundamental function that should work. Suppose he was flashing the stock Arnova ROM per the Arnova web site? All in the limits of the warrenty! So custom ROM or not, a hardware failure is a hardware failure and should be taken care of.
Problem is based on others posts I have seen recently. It appears Arnova has stopped production of this tablet and none can be had anymore. The bummer is they may not have one to give him in it's place
Problem with Droidwall
Hello Bob, I'm writing from Italy. I installed your ROM v.1.4 on my tablet Lazer 10.1, everything works fine. I installed Droidwall, but I had some problems making it work. When I enable the firewall, it gives me an error: Error applyng iptables rules. Exit code: 2 iptablesv1.4.10 iptables v1.4.10: can not initialize iptables table 'filter': Table does not exist (do you need to insmod?) Perhaps iptables or your kernel needs to be upgraded. How can I fix this? Another small question: Which button do I press to get into Recovery Mod?
Sorry for my English ...
Thanks in advance.
bt dongle
Originally posted by Finless View PostI can add Finec57 BT dongle dirvers to this but I do not know what dongles the drivers support!!!!!
So it will be a total hit and miss. If you like to try it and give feedback and be a tester let me know.
The Arnovas do not have iptables. Very common complaint. Not much I can do about it without kernel source.
I will add the BT drives and post a BETA TEST later today. Not feeling well today Iseem to have a cold or something.
The limit is because of the SDcard file system being fat32.
It is in theory possible to repartition the sdcard in linux making a part of it fat32 and another part ext3. Then on the tablet using a terminal emulator mount the ext3 part.
I have not had time to see about how to go about this but it's on my list.
Originally posted by DG19075 View PostBIG ups to Bob and the crew for this ROM. Installed it this week on my replacement 10G2 as trhe original's power jack center pin broke. Boots very fast and everything runs like magic.Now all I need is to find Dolphin Browser Mini,and I'm all set!
I've been using 1.5b since just a few minutes after it was posted. I didn't use 1.5c because my version of Play Store worked fine. This new ROM is great!
After a couple of weeks after the flash, I've noticed only one problem. I can't tell if it's a hardware or software issue. After several hours of use without a reboot, I am unable to save or delete any files on my sd card. It reads fine. Last night, and I left the tablet on to try the scheduled backup feature in titanium. This morning I had a notification that there wasn't enough space on the sd card when there was actually 16gb free. X-plorer grayed out delete. After a reboot, everything went back to normal.
I'm wondering what causes this and how to fix it.
Otherwise I'm very pleased with the improved functionality with this new ROM!!!
Sent from my AN10G2 using Tapatalk 2Randy
Please read this post about sdcard issues. If the sdcard file system gets corrupted in any way, it will be mounted as read only!!!!
http://www.freaktab.com/showthread.p...Understand-WHY!
I haven't tried the fix yet, but it makes sense. I never did anything in Windows after I turned off USB, thinking I was done. I'll see if I corrupted the SD.
Thanks for the quick reply. AND thanks for the hard work on your ROMs. Archos puts out a decent set of hardware, but the custom ROMs you do make them a whole lot more useful.
I am here: http://tapatalk.com/map.php?knxjj1Randy
I finally got around to checking the file system on my SD card in Windows. Sure enough, there were some errors, which were fixed.
Thanks for the info.Randy
There are currently 1207 users online. 24 members and 1183 guests.
Most users ever online was 7,737 at 14:33 on 01-16-2020.
