Arnova 10 G2 Custom ROM by Finless Version 1.5
Guest
Originally posted by Zuggy View PostGoogle Play Store updated itself silently to 3.5.16 on 1.5b ROM, so I didn't have to update it with app injector.
bricked ?? help please
Hi Bob i previously loaded 1.4 with no problems and so decided to go for 1.5 . It seemed to go ok , I saw it reboot then nothing..blank . and now nothing happens . I tried putting it back into recovery mode (volume up . reset pin ), the computer says it usb not recognised , but nothimg appears in device manager. tried running rk 29 but obviously it does not see the tablet. so im at a loss how i can restore anything to the tablet . any ideas where i go from here please
Originally posted by jem111111 View PostHi Bob i previously loaded 1.4 with no problems and so decided to go for 1.5 . It seemed to go ok , I saw it reboot then nothing..blank . and now nothing happens . I tried putting it back into recovery mode (volume up . reset pin ), the computer says it usb not recognised , but nothimg appears in device manager. tried running rk 29 but obviously it does not see the tablet. so im at a loss how i can restore anything to the tablet . any ideas where i go from here please
Sent from my SK17i using Tapatalk 2Please consider donating to purchase tablets for Finless Bob to continue his work. This will help in the creation of custom roms and build an even stronger development base for our community. Thank you for you support!
</form>
Originally posted by Damo View PostYou need to long press the power off button and make sure it is definitely off. Repeat you steps to put it back into recovery mode. Now reflash again, sounds like a bad flash first time
nooby here
I was just wondering if anyone could guide me on 3G support. I have a Huawei e160g and a ZTE mf112 dongle and just want help on getting these to run
any help will be greatly appreciatedLast edited by H88RRY; 04-12-2012, 21:54.
Have you rebooted your computer since you flashed, quite rarely a reboot on your pc is needed due to a system lock. Up.
</form>
Was your battery level okay before you started?
You should always be able to get these into recovery mode unless your tablet is seriously bust, or one of the buttons for recovery mode is jammed.
Try giving it a charge or plug it in and try again
Sent from my CUBE U9GT 2 using Tapatalk 2Please consider donating to purchase tablets for Finless Bob to continue his work. This will help in the creation of custom roms and build an even stronger development base for our community. Thank you for you support!
</form>
Originally posted by Damo View PostWas your battery level okay before you started?
If your flash ROM failed then your tablet is dead. Lets hope not. Make sure maybe your USB cable has not failed in some way? etc.... But know that since I have been doing this I have seen about 4 tablets flash ROM fail even after successful flashes before! It is possible. As Damo said if the hardware has not failed you cannot permanently brick these tablets.
There are currently 1163 users online. 26 members and 1137 guests.
Most users ever online was 7,737 at 14:33 on 01-16-2020.
