Netflix in HD is being killed in some of the Chinese boxes.
Originally posted by mymo View Post
I just quote to specify it's the tablet version
Inviato dal mio Redmi Note 4X utilizzando Tapatalk
Originally posted by XXBrain
Thank you very much, mymo. Seems to play with much more quality than any version I installed from apoide. So the device is still able to play the content but som check in the original app is the problem. I will also test the hide rote option when i find some time for it.
Anyway, you guys please check what Netflix support wrote me this morning
mine facing the same problem.. cant watch netflixx via android tv app.. if install netflix android version is ok.. but do not support hd.. bougt the box for netflix hd...anyone have solution..? btw my box using the ir remote not the bluetooth one..Last edited by hadrabad; 01 August 2018, 12:46.
Originally posted by malik500 View Posti tried to download your netflix apk clarkss12. but its not found i think it is removed. have you tried test pattern from netflix to test if it runs 1080p
Originally posted by mymo View PostFor those willing to try, there's a Netflix plugin for Kodi 18
Unfortunately videos won't start on my box, but if they did this could be a good alternative for those who don't mind using Kodi
Sadly, I have already cancelled my subscription
Any advice?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I downloaded and installed the zip file onto my Android version of Kodi 18, but it won't play. I think it is missing the input stream, or whatever it is called. It shows the users and the video files that are available, just like a regular Netflix interface, but will not play the videos. I had it running on one of my LibreELEC boxes in one of the bedrooms.
Any advice?
Any advice?
I doubt if this is a setting issue with inpustream, because Amazon addon relies on the former as well and it does play videos
There are currently 2894 users online. 0 members and 2894 guests.
