Netflix in HD is being killed in some of the Chinese boxes.
Originally posted by polartic View PostSo those of us who have a pro + will not have a solution? (sorry for my bad english)
test send email here -> [email protected]
explain the problemSorry for my badly english
Originally posted by clarkss12 View PostHere is the link that Snakx posted to resurrect Netflix in 1080P HD....
Scroll to post #60. Could not get a direct link to that post.
http://freaktab.com/forum/tv-player-support/amlogic-based-tv-players/s912/mecool/737833-netflix-in-hd-is-being-killed-in-some-of-the-chinese-boxes?p=738327#post738327
Well, it appears that it has finally happened, Netflix in HD has stopped working on these Chinese boxes that are NOT Google Certified. Tested my Mecool M8S Pro L and my Mecool M8S Pro Plus, both get an error now when trying to play Netflix in HD. Question is whether Mecool or others will be able to correct this issue via firmware upgrade, or is it an embedded hardware problem that can't be solved.
But for me, that is not the end of the world, I can always use Netflix in 480p, if worse comes to worse.
Edit: Posted a version of Netflix on Dropbox that will Play Netflix in 1080p HD........
https://www.dropbox.com/s/5alkplnfo0....5_HD.apk?dl=0
I removed the app, not sure if it's legal to post it.
Another option of getting Netflix in 720p, is by using LibreELEC. This video is a year old, but it still works. You install LibreELEC on a microSD card and dual boot from your Android box. It does not affect your existing Android. I think it also supports Amazon Prime, but i don't subscribe to the Prime, so I can't confirm.
https://www.youtube.com/watch?v=_kiqQnY2e_c
Originally posted by tork24 View PostCan someone with a M8S Pro L box post the /system/build.prop file of the box, I would like to try something.
Originally posted by JANE View Post
when a click on your link I just see my home dropbox?
file deleted?
Here is the smali file corresponding of the burn process. It takes on bin file following the box model, check also something concerning the mac address and do some write.
It loads keyburn and jnikeyburn library included on the jar file. I think it should be possible to use the same mechanism if we can find the correct bin file...Attached Files
Originally posted by tork24 View PostWhat do you mean by encrypted?
Do you think if we modify the BurnActivity class to force the write of one of the bin file to the M8S Pro+, it could work?
Or the bin file is really linked to one device?
as the file is small it looks easy, but the compiled/encrypted binary(key) it will be extremely hard to translate, especially with so little code
open the key with a hex editor, you will see what i mean
Hello,
What I don't understand is that on my brand new mecool KM8 which have AndroidTV 8.0 by default (factory settings) I already have a good status relating to the google DRM from DRM INFO.
the fix just update the DRM certificate?
the AndroidTV netflix app is available on the google playstore but not detecting my device as compatible...
If someone could help me to understand what netflix done exactly to "BAN" the chinese box, it would be nicely appreciable.
Best regards,
Best regards,
It could even be my research that has triggered this secondary check
If I understand correctly, the google WVL1 DRM Bin/Cert is specific for eatch product and google after a failled negociation with manufacturers in order to get more money just invalidate the current cert for many many legit product?
if it's that :/ it's clearly a shame...
My KM8 is google certified and Mecool/videostrong had paid for that and for the WVL1... it's simply a hostage taking
Originally posted by fatahltk View PostIf I understand correctly, the google WVL1 DRM Bin/Cert is specific for eatch product and google after a failled negociation with manufacturers in order to get more money just invalidate the current cert for many many legit product?
As friendly as both google and netflix are aswell as the opensource development encouragement, they will still make sure they are making some money
There are currently 2922 users online. 1 members and 2921 guests.
