do you know how I can install the firmware they sent me?
Netflix in HD is being killed in some of the Chinese boxes.
Originally posted by Smallville3009 View Post
Gearbest have sent me Firmware that they say is for my box but it failed went to recovery mode saying it is a previous version.
do you know how I can install the firmware they sent me?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Can you copy that file to a place like dropbox, Google drive, ect, so we can take a look.. I forgot, which version of the "L" do you have?
my firmware says. M8S PRO L 20180803.173707.V0213
MY BOX JUST SAYS M8S PRO L LB.
will look into uploading the firmware, need to make an account.
Did they send me the wrong firmware?
The firmware they sent is. M8S_PRO_L-ota-20180417.150752.V0213 it says it's for the M8S PRO L 4335 I don't know if this is my version?
Did they send me the wrong firmware?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
That is an older version of the firmware for the "LB" box......... You have a newer version, that is why it won't install....... Even so, if it did install, it would NOT bring back your DRM level 1.
Thank you for your help. Don't know why they said it would. Gonna send it back for free repair after talking to them. Just a shame it's gonna take like 2 months to get back to me..MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
That is a good solution if it doesn't cost you an arm and leg to send it back.
It's the time for them to send it to China manufacturers, then repair. Then all the way back not knowing what caused the DRM issue, what's saying it won't happen again
That's why I was trying my best to find out what happened.
Just have to hope they actually fix the DRM as the gearbest rep didn't acknowledge it as the issue.
Originally posted by stipo80 View PostNetflix is not working again on my K3 Pro. It was working after aplying the BurningKey 1.03 but not anymore. I tried reinstall, applying the key again and factory reset but still not working. Anyone else with same problem?
There are currently 3706 users online. 0 members and 3706 guests.
