Netflix in HD is being killed in some of the Chinese boxes.
what do you mean exactly, I have to edit the file, so that the installation works?
Nothing in the whole thread. And nothing in the manual.
You can't edit any file, as the burnkeytool is not compatible with your device.
Contact Videostrong to release a working burnkeytool for your device but they will probably tell you to buy one of their new devices instead.
Are you looking for Netflix Apk than i will refer you one site that can help you to download Netflix Apk for Android And Android TV Netflix APK
Hi Everyone,
I'm an android developer and I recently acquired a chinese android box from VideoStrong : Meecool KM8 google certified
As you know Netflix android TV version are prohibited or limited for these android TV Box.
I try so many version linked on XDA forum, freaktabs, etc... without success.
I finally found the Netflix [3.2.2-Android TV Mod] apk by tork24 (DeaLabs.com) which is working in HD but NOT in ULTRAHD
So I decided to rummage the official netflix app, and I found that Netflix app looks for some system properties that I want to share.
Here, there are :
sys.amazon.devicename
sys.display-size
vendor.display-size
ro.nrdp.modelgroup
ro.vendor.nrdp.modelgroup
ro.nrdp.oemmodel
ro.vendor.nrdp.oemmodel
I found how to run Netflix in ULTRAHD mode :
Requirement:
- Download the Netflix [3.2.2-Android TV Mod] apk by tork24 : https://drive.google.com/file/d/1qkK...8F4X-Ywcg/view
- You need a box with Google widevine L1 available
- Find a way to hide that your android box is rooted or unrooted after modifying build.prop
Follow these steps
1/ Your android box is rooted
- add/modify this line to your /system/build.prop :
ro.nrdp.modelgroup=FIRETVSTB2015
sys.display-size=3840x2160
- Unroot your box
2/Your box is NOT rooted
- Enable Debug USB mode
- type this command
adb ro.nrdp.modelgroup FIRETVSTB2015
adb sys.display-size 3840x2160
3/I DON'T UNDERSTAND
Don't worry I made an app that do the job for you.
You'll just have to launch it, instead of netflix app.
You can download it here :
https://drive.google.com/file/d/1qKD...DLs91A4uy/view
or
https://mega.nz/#!d4FniSYZ!sQ-20oDVR...wLkdlpPITOvftw
I hope this thread can help you to enjoy Netflix ULTRAHD.
This method also work to use the Netflix app (6.17 build version) form the PlayStore, but only for HD.
Just ignore the error -14 message the first time you launch my app.
Sorry for my bad English.
If you want to let me a cookie, it is there :
Give that dev a cookie -> https://www.paypal.me/yablio
PS : I'm working to how to exploit the ro.nrdp.oemmodel system property. If anyone have an idea...
Originally posted by mparahir View Posthello i update my mecool kiii pro stock rom android 7.1.2 but in playstore no found neflix,i download from apkmiror install netflix but is writting no compatible with device wtf?
See my post above...
Originally posted by William Grondin (Yablio) View Post
Netflix is only compatible with some certified box only. There is a tick to fool the netflix app and make it compatible.
i have a trouble
code error tvq-pm -100 (5.2.5) , i can play only the 4k uhd movies ,,, all the others after 15/20 seconds gives me error tvq-pm -100 (5.2.5)
Originally posted by goblen View Post
hello .... does not work on my m8s pro l ( lq)
i have a trouble
I had this error error too. Disable the surround sound in settings>sound. Unplugged any USB devices and reboot. I don't know why but it works for me.
thank you for reply ? but still not work , what firmware are u using , mine is the latest nexus tv ( magendaz) , is your rooted ?
Yesterday my Mecool M8S pro L stopped playing netflix again. I am getting "this title is not available to watch instantly" errortvq-pm-103. I tried burning the key again with the tool...no luck. I found some posts on a polish site with a few people all experiencing the same thing since yesterday
This on going issue is why I don't play with these low cost boxes with L1 drm. If I wanted L1 i'd get a shield tv or an Amazon Fire TV, or a new name brand TV that supports L1.
since the late 80s products have been forcing us to upgrade after 1 to 2 years. As full product support became phased out to new product releases. If you want the latest features now, you will pay for it, without any guarantee that it is 100% functional or supported after Warrenby. Problem is, the features you pay for will be replaced before you get your monies worth out of it.
outside of the above, its the peeps fault this is happening. Yes, you peeps! You buy into false claims, 90% fully functional, and partial support of any given product. Look at all the smart phones, and laptops that are wonky, yet peeps buy them even though the will deal with issues. He big problem is upgrades to newer products, hoping what they get is better, but realisticlly the product is not 100% functional or as reliable as they expect.
it took me a few years to make my 4 year old tablet with proper, and it runs kitkat. I won't bother with any other replacement. Just too much to deal with for not much better improvement.
There are currently 2397 users online. 0 members and 2397 guests.
