Netflix in HD is being killed in some of the Chinese boxes.
Originally posted by Wanderyx View PostHello, I used bk1.0.6 and my netflix came back to work thank you very much. Now I have a doubtd , my Tv and fullhd and I have a m8s pro 3g 32gb and says it catches netflix in 4k. But that only if my TV is 4k? Because on YouTube I squeeze in 4k.
Originally posted by JoseM View Post
try version 1.06 http://freaktab.com/forum/tv-player-...632#post740632
Is this solution for Netflix as functional for the French MyCanal streaming application that does not want to work on the TV box Mecool TV?
Or is there a solution for MyCanal that uses DRM but also checks if the system is root or not?
Hello, I get a mecool kii pro with 7.1.1 firmware with malaysk. The netflix 5.4.1 app bring me the possibility to use the remote control correctly, but in the beginning give me an error (tvq-pb-103(1.10.5005)). With another mobile netflix version the videos loaded correctly, but I couldn't use and move correctly the remote control.
Any solution? Thanks
Originally posted by yougz View Post
Hello,
Originally posted by xmatrix83 View PostNew response from the support about the m8s pro:
Pls find the update link of MEGA.
Sincerely Yours,
Candice
I think this is an OTA update for the stock rom, unfortunately I use ATV rom and I can not try
I've tried the OTA firmware update... Netflix is back alright , but I couldnt get more that 480p (verified by running 30fps Netflix test pattern) from this
I've also ran the 1.06 burnkey apk, it was successfull but netflix is still running on 480p.
Any help ?||
Update after a few hours after the above post :
after much tinkering , I managed to get 720p out of my box. I'm using the latest OTA update and Netflix from post #255 :
Originally posted by pégaso View Post
If you have Widevine LV 1 you can use Netflix for conventional Android.
https://mega.nz/#!7hcUHYjR!PGYtjzfC4...5AXr1ZQR9WcAuk
(App modified for devices without certification from Netflix but with Widevine LV 1).
How do you get this APK ? I've backup the latest Netflix of my mobile but still couldnt go to 720p ....only the one provided on post #255 managed to get up to 720p.Last edited by hassanJ; 10 September 2018, 11:25.
Originally posted by hassanJ View PostHow do you get this APK ? I've backup the latest Netflix of my mobile but still couldnt go to 720p ....only the one provided on post #255 managed to get up to 720p.
Originally posted by paggui View Posthi
i also got netflix error NW-6-404 on mecool KII device. suggested solutions like "BurnKeyTools" don't work. Someone have solutions for this?
Originally posted by fafan View PostIt seems mecool have been banned again by netflix
I have the PRO L with voice remote version
After the block in end July it was solved by the fix but it is again blocked now.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 3550 users online. 0 members and 3550 guests.
