Netflix in HD is being killed in some of the Chinese boxes.
Originally posted by Sholander View Post
Don't waste your time, NO Netflix in Kodi on any Mecool box for the time being. Not in Kodi and not in CoreElec Kodi...
Android Kodi also works on my Mecool box, but only in 540. You have to disable Widevine L1 and force L3. I use liboemcrypto disabler module in Magisk, or try renaming liboemcrypto.so in system/lib with a .bak extension. For 540 quality though, it's much easier just to use the Netflix app (and yes, the app works too, just have to find a Netflix 4.xx.xx or 6.xx.xx build that works on your box).
For 720 quality Netflix on a Mecool (or other) box, install CoreElec with Kodi 18.1 on a microSD card:- Follow this install guide: https://coreelec.org/#download
- Reboot to the microSD card (see Learn More in the install guide), e.g. Mecool M8S pro LB uses the menu button method, Mecool KIII pro uses the toothpick method.
- With CoreElec Kodi up and running, install the Netflix add-on for Kodi: https://forum.kodi.tv/showthread.php?tid=329767
- Netflix also needs inputstream.interactive installed. Look in the CoreELEC Add-ons repository, otherwise download and install the latest zip: https://relkai.coreelec.org/?dir=add...tream.adaptive
Originally posted by Hideiyoshi View Post
Incl Minix ke?
Originally posted by Snakx View Posthi,
have sent a mail to videostrong for my m8s pro LLB version . have get an answers with this .zip
it's burn key tool apk and normaly it's for the problem with netflix.
i can't test now i'm at work
Hi,Jeremy
I'm Lily from Videostrong. About the problem of nextflix. Pls find the attachment.There is burn key guide in the file. It can help you to solve the problem.
Best Regards
Lily
Sales Director
Videostrong is an Original Manufacture of Android tv box/STB/Hybrid Box.
__________________________________________________ _
Hi Lily,
thanks but the problem is the google certification. netflix banned all box without google certification. burn key tool it's just for the widevine drm ?
In my M8S pro L the widevine L1 drm are ok
Best regard
Jeremy
Hi,Jeremy
It's for Netflix problem, not for the widevine drm.You can have a try.
Have you try this burn key tool? Dose it work for you?
I run this tool, and got success, but still not work.
Or need to install some special version Netflix app?
Originally posted by icybug View Post
Hi Snakx,
ThanksSorry for my badly english
not work now. Install the tablet version of netflix
Is it this version? Still not work, could you share a link to me ?
Or with the inbuilt root you rename liboemcrypto.so to liboemcrypto.so.bak and you deactivate the rootLast edited by Snakx; 21 March 2019, 16:11.Sorry for my badly english
Since a few days ago we had comments from our users that suddenly have Netflix incompatible in the Google Play store and Android TV-Box device cant install
There are currently 6213 users online. 1 members and 6212 guests.
