Latest addon versions are here https://github.com/CastagnaIT/plugin.video.netflix
Netflix in HD is being killed in some of the Chinese boxes.
You can use Magisk to spoof another device.
DRM licenses are burnt into write once special areas on the emmc storage chip and encrypted.
It can't be copied or moved to another device and is also linked to the actual hardware serial numbers inside a device.
So it's not possible to do it.
If another manufacturer is using a hacked certificates(some Amlogic S905x manufacturers did it), Google will blacklist them soon and all Google apps together with DRM streaming apps will cease to work on such a device.
Just buy a S922x device that can run CoreELEC with the 1080p Netflix addon.
Originally posted by LoKin View Post
I downloaded Magisk and Magisk Manager on my Mecool M8S Pro L android TV box. I looked through the Magisk modules, but I couldn't find the module that would allow me to spoof another device. Can you share with me the name of the Magisk module that will allow me to spoof another device?
I did some research and found that Netflix relies on the Electronic Serial Number (ESN). Is there a Magisk module that can change the serial number?
I followed all of the directions, downloaded the Busybox module. and set the fingerprint to a Google Nexus player. And it still didn't trick Netflix to think I was on a Google Nexus player.
Edit :
Use mibox 3 spoof with magisk
with "fingerprint" the first choice
ro.build.fingerprint=Xiaomi/once/once:6.0.1/MHC19J/540:user/release-keys?
with "new custom prop"
ro.build.description=once-user 6.0.1 MHC19J 540 release-keys??
ro.build.product=once?
ro.product.manufacturer=Xiaomi??
ro.product.brand=Xiaomi?
ro.product.device=once?
ro.product.model=MIBOX3 ?
ro.build.id=MHC19J
ro.build.display.id=once-user 6.0.1 MHC19J 540?
ro.nrdp.modelgroup=XXIAOMIM12TRIAL
Envoy? de mon XT1562 en utilisant Tapatalk
Sorry for my badly english
Originally posted by techuntouch View PostIf Netflix not working for you then there are many other live tv streaming sites available.
one question, i try it in stremio and dont work to
There are currently 3954 users online. 0 members and 3954 guests.
