Netflix in HD is being killed in some of the Chinese boxes.
Originally posted by zenix View Post
I know. Kodi doesnt work .Netflix app working fine but sd
Wrong, the Mecool KM8 is Google Certificated, and it used the Google Play store version of Netflix and it played in 1080p with DD+ audio.
KM9 does not rotate in HD: https://androidpc.es/review-mecool-km9/
Originally posted by pégaso View Post
KM8 with modified app: https://androidpc.es/review-mecool-km8/
KM9 does not rotate in HD: https://androidpc.es/review-mecool-km9/MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by panchovilla View Post
Or buy a smart tv that already has those apps.
My Samsung curved tv has incredible UHD Netflix and Prime .
They're giving away 4k sets with Fire and Android built-in too.
Originally posted by sepa View Post
Mecool L1 boxes only ever worked in SD UNLESS you also used a modded Netflix app that forced HD. Those apps are now blocked by Netflix, which will only work with apps that also stream SD.
Edit: I meant apk instead of app
Originally posted by mymo View PostWhat kind of (to use a euphemism) silly suggestion is that? A TV is the most expensive device in a media center, it's like suggesting a person who doesn't like their car stereo to buy a new car. We discuss tv boxes here, please stay on topic, nobody is here to read about your TV.
I see no reason why peeps whine over a cheap Chinese box about L1, when they should have bought a retail certified box or TV, as many seem to be expecting the box to fix what their TV and audio system lacks. If you spent money on a big screen TV without L1 built in, then it must be over 6 years old, and it will need to be replaced, or you did not do your home work, and cheaped up on the purchase.
fandango-fr and mymo
Most if not existing m8s pro l or even mecool are having netflix except both of you... do check again or provide us the link to download/test
There are currently 1439 users online. 0 members and 1439 guests.
