Netflix in HD is being killed in some of the Chinese boxes.
Originally posted by Matias_Brazil View Posthow to install corelec 8.99.2 in box mecool m8s pro L?
Enviado de meu Redmi Note 4 usando o TapatalkMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
If it's to be a lazy burglar who does not know how to use Google then you better get out of here! You idiot!
Originally posted by bratmat View PostIf You want Netflix on K III pro or other s912 devices try corelec 8.99.2 - best solution - Kodi will give you better functionality for almost everything : TV application is very good - you can edit list of channels on your PC computer or directly in the box. Netflix works great in 720p resolution. You don't need original remote, Tv remote with CEC works great. You can operate your box on your PC with kodi webserver.
And you can make a dual boot (Coreelec on SDCARD and androidTV on emmc inside the box)
I'm very satisfied
Originally posted by pégaso View PostDoes not record run at 1080p by limiting the addon or why if running in 1080p have playback problems?
Inputstream addons use software decoding not hardware decoding.
You will see Widevine on a Linux PC also uses software decoding and not hardware decoding, that's how Google designed it.
There are currently 2847 users online. 0 members and 2847 guests.
