Netflix in HD is being killed in some of the Chinese boxes.
Originally posted by Zahir View Postpanchovilla - it's intended for boxes with Widevine L1.that haven't been "certified" by NFix. On those boxes, it should ramp up to 1080p and works best with an air mouse.
Those Youtubers have cheerfully appropriated my mod, added a shortcut and passed it off as their offering..
Originally posted by kos25k View Posti read that installing and booting coreelec to/from microSD,downloads and installs WidevineL1 files to microSD and then u can play on HD.Didnt try though cause i didnt know where to save repository zip files to insert on netflix and then i formated microSD with coreelec.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I see that you are using a Vorke Z6 which is an Amlogic S912 Soc with gigabit Ethernet which is very good. Do a search for "repository.castagnait-1.0.0" and download and install his repo. His repo will install everything you need to get Netflix up and running.
Originally posted by kos25k View Postthanks mate i'll try.But where do I put this repozitory on micro sd?I remember box wasn't recognizing a usb stick with other repozitories I was trying to insert.Maybe do I have to put them after burning coreelec on my microSD on PC on some folder?Also the repository yoy mentioned,is for kodi or for coreelec?
If you have any storage devices connected to your network, CoreELEC/LibreELEC/OpenELEC can access that device. In my case, I have multiple networked storage devices (NAS's), so I have all my repo's and app zip files store on one of those devices. When I install a new OS, I just point the OS To the storage device that has the repo's that I wish to install.
Originally posted by kos25k View PostNice thanks.But I don't have PC..Only my tv box!So I save to put this file on download folder of coreelec on microSD?But I remember there wasn't such a folder,and then I gave up with Netflix installation..MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by kos25k View Postfrom my parents mini PC Vorke Z1 that I gifted to them!MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
No,I meant this pen drive wasn't recognized from my tv box,so to just choose it from coreelec to install!On pc will be easy..But as I said,I don't remember a "download" folder inside coreelec folders.And I am afraid that if I create a new downloader folder inside coreelec contents,maybe then coreelec won't boot from my tv box!
There are currently 1314 users online. 2 members and 1312 guests.
