Netflix in HD is being killed in some of the Chinese boxes.
Originally posted by Hideiyoshi View PostNot sure if anyone tried this.. https://www.youtube.com/watch?v=L07EFUnszyo
But for this version, if you don't upgrade, it will not run. So that make this apk a useless one.
IOW, this app version has been black listed.
Perhaps somebody can trick the version number again.
Originally posted by Hideiyoshi View PostBTW I'm using this combo to get netflix HD on my Toshiba ZV series full HD TV. But without 5.1 channel
The first file package name is com.yablio.netflixuhdfix and second one is com.netflix.ninja.
Originally posted by mctiew View Post
You are showing information that you are NOT using the combo. In one of the picture, you showed com.netflix.mediaclient 4.16.1, that is not from the combo.
The first file package name is com.yablio.netflixuhdfix and second one is com.netflix.ninja.?
Then you are contradicting yourself. One sentence says using the combo ( apks) another picture shows you are not.
The same apk are used on KM9 Pro Classic and no problem with HD netflix
I have used the method posted on the YouTube above on KM3 Pro and it worked in Netflix HD but the box is now with someone else
Originally posted by mctiew View PostLiterally no idea what you are talking about.
The two netflix apk combo the first file package name is com.yablio.netflixuhdfix and second one is com.netflix.ninja.
But your picture showed com.netflix.mediaclient.
@Hideiyoshi
as requested earlier, we all would greatly benefit if you share your apk files so that we can try and perhaps succeed.
Originally posted by hannah View Post
I am with you here too.
@Hideiyoshi
So far, only various reports of success in streaming upto FHD. To get 4k, these must be satisfied :-
1. DRM L1
2. Hdcp 2.2
3. Netflix certified ESN.
Netflix is probably constantly blacklisting more and more faked ESN, so more and more modded Netflix apk will fail to work.
Originally posted by blaze2051 View PostFor the KM 9 pro and KM 9 pro classic which one of these actually and can confirm to have
HDCP 2.2 and Gwidevine Level 1?
can anyone help confirm ?
There are currently 1555 users online. 2 members and 1553 guests.
