Netflix in HD is being killed in some of the Chinese boxes.
Originally posted by dados View Post
I think, you all don't understand, what i say.
I made a totaly new image for m8spro lq.
Reflashed the box and owerwritten hdcp, serial and widevine.
Now my box have a totaly new device-id for Netflix.
Just now watching Netflix HD on ATV.
Would you kindly share the process of doing this so that we / I can do it myself. Thank you for your help in advance
If you wan to download Netflix Premium Apk then today i will share with yo 100% working Netflix Premium Apk. Just visit this site and download this app and enjoy the netflix for freeDownload Netflix Apk and enjoy your favorite Movies and TV Shows for Free. Get Now Netflix Premium Apk and start streaming your favorite content.
Found this thread because I had the problem that netflix versions didn't work at all or that I had no sound.
This video worked for me:
In short:
install older version(s)
Get/install Aptoide Appstore on your device
search for netflix
change and install version 6.26-1-build-15-316 from mr.robot
works for me
edit:
arf...only 480p againLast edited by Ullulaki; 17 January 2020, 19:53.
Originally posted by Ullulaki View PostFound this thread because I had the problem that netflix versions didn't work at all or that I had no sound.
In short:
search for netflix
works for me
edit:
I tried downloading netflix apk, but it got an error, could someone please fix it for me?Last edited by Kariwilliamson; 25 March 2020, 02:46.
My netflix was working beautifully at 1080 for al long time on a Mecool KM9 Pro.
Today i installed a second Mecool KM9 Pro box with the same 2 netflix apk's but it didn't work.
When i start a video i get a black screen with text saying "can't play this video with your account" (In dutch so it might be slightly different in english)
I tried different apk's and settings nothing works anymore.
I logged off and now even my primary box won't work either......apparently, if you log off, you log off on all devices ........
Now both boxes won't work anymore with Netflix.
Any new fixes i can try??
Originally posted by G-Member View PostMy netflix was working beautifully at 1080 for al long time on a Mecool KM9 Pro.
Netflix now also blocks old apps from not working anymore and you need to use the latest apps.
The latest apps now also check Safetynet, so if your device is rooted or not Google Certified it won't work unless you use Magisk.
Probably not as Google blacklisted the Widevine key used for Netflix again on the KM9 Pro.
Is it in HD?
Thank you
Originally posted by William Grondin (Yablio) View PostHi Everyone,
I'm an android developer and I recently acquired a chinese android box from VideoStrong : Meecool KM8 google certified
As you know Netflix android TV version are prohibited or limited for these android TV Box.
I try so many version linked on XDA forum, freaktabs, etc... without success.
I finally found the Netflix [3.2.2-Android TV Mod] apk by tork24 (DeaLabs.com) which is working in HD but NOT in ULTRAHD
So I decided to rummage the official netflix app, and I found that Netflix app looks for some system properties that I want to share.
Here, there are :
sys.amazon.devicename
sys.display-size
vendor.display-size
ro.nrdp.modelgroup
ro.vendor.nrdp.modelgroup
ro.nrdp.oemmodel
ro.vendor.nrdp.oemmodel
I found how to run Netflix in ULTRAHD mode :
Requirement:
- Download the Netflix [3.2.2-Android TV Mod] apk by tork24 : https://drive.google.com/file/d/1qkK...8F4X-Ywcg/view
- You need a box with Google widevine L1 available
- Find a way to hide that your android box is rooted or unrooted after modifying build.prop
Follow these steps
1/ Your android box is rooted
- add/modify this line to your /system/build.prop :
ro.nrdp.modelgroup=FIRETVSTB2015
sys.display-size=3840x2160
- Unroot your box
2/Your box is NOT rooted
- Enable Debug USB mode
- type this command
adb ro.nrdp.modelgroup FIRETVSTB2015
adb sys.display-size 3840x2160
3/I DON'T UNDERSTAND
Don't worry I made an app that do the job for you.
You'll just have to launch it, instead of netflix app.
You can download it here :
https://drive.google.com/file/d/1qKD...DLs91A4uy/view
or
https://mega.nz/#!d4FniSYZ!sQ-20oDVR...wLkdlpPITOvftw
I hope this thread can help you to enjoy Netflix ULTRAHD.
This method also work to use the Netflix app (6.17 build version) form the PlayStore, but only for HD.
Just ignore the error -14 message the first time you launch my app.
Sorry for my bad English.
If you want to let me a cookie, it is there :
Give that dev a cookie -> https://www.paypal.me/yablio
PS : I'm working to how to exploit the ro.nrdp.oemmodel system property. If anyone have an idea...
help on Netflix please
The 2 apk trick let's the Netflix app think it's running on a Firestick
Now the fun part...... i got one box running Netflix HD again..
First i killed both Netflix apps, then clear cache and data from both apps and uninstalled both apps.
Shut down the box and kept it unplugged for a couple off minutes and booted again.
Reinstalled both apk's
First i started up the Netflix app with the black icon untill you can enter your credentials (don't do it)
Went back to the homescreen and started the second Netflix app with the white icon.
Set up my account and it worked again.
But i can't get it to work on my second identical box........ Can't figure out why
Google did not blacklisted the Widevine key, Netflix won't support any box withouts the ESN certificate key.
There are currently 2517 users online. 2 members and 2515 guests.
