https://mega.nz/file/YchjjK6J#PZoRxS...jcmUwHVGqvfr5c
Netflix in HD is being killed in some of the Chinese boxes.
Originally posted by Ekay View PostHere is Netflix ATV version (no airmouse required) for Mecool devices, but only 480p resolution.
If yes then we can create our own build.
Guest
Originally posted by hannah View Post
Do you know how was this build created? Please share.
I just wanted to share it with you guys.
Originally posted by G-Member View Post
Google did not blacklisted the Widevine key, Netflix won't support any box withouts the ESN certificate key.
The 2 apk trick let's the Netflix app think it's running on a Firestick
Now the fun part...... i got one box running Netflix HD again..
First i killed both Netflix apps, then clear cache and data from both apps and uninstalled both apps.
Shut down the box and kept it unplugged for a couple off minutes and booted again.
Reinstalled both apk's
First i started up the Netflix app with the black icon untill you can enter your credentials (don't do it)
Went back to the homescreen and started the second Netflix app with the white icon.
Set up my account and it worked again.
But i can't get it to work on my second identical box........ Can't figure out why
From this app https://azshow.info/watch/nQuA_l43OQ...tflIx-fIx.html
I rebuilt it a bit
added an icon for ATV now works with LEANBACK_LAUNCHER, no sideload launcher needed,
changed view to smallscreen
Code:screenSize|smallestScreenSize|uiMode
Code:smallestScreenSize|uiMode
Code:android:banner="@drawable/ic_banner"
Code:android:name="android.intent.category.LEANBACK_LAUNCHER"
Originally posted by Paveki View PostFrom this app https://azshow.info/watch/nQuA_l43OQ...tflIx-fIx.html
I rebuilt it a bit
https://mega.nz/folder/UtkDSCKB#LrPhzAOf1C8abKJ-hQ1biw
There are currently 3533 users online. 0 members and 3533 guests.
