Netflix in HD is being killed in some of the Chinese boxes.
No, that is not the reason. Most probably you are using wrong dtb.img...
Did you read instruction for installing CoreElec ?
Which dtb.img are you using ? Did you copy the proper one from "device_trees" folder to root of uSD card, and renamed it to dtb.img ? Since there is already a "dtb.img" file on root of uSD card you have to delete that one and use only the proper one for your box from device_trees folder.
Btw, which box do you have, and which dtb.img did you use ?
Try with "gxm_q201_3g_1gbit.dtb". This one I use with my X92_S912 box.
My box boots OK with gxm_q201_3g.dtb and gxm_q200_3g, but with with these either ethernet is not 1gbit or wifi is not full speed...
If it's not dtb.img I don't know what else to do, except new image download and new flash to uSD card. After you finish installation then copy to uSD those repository zips... During initial install take out all USB disks/flash drives.
Originally posted by Sholander View PostTry with "gxm_q201_3g_1gbit.dtb". This one I use with my X92_S912 box.
Στάλθηκε από το VORKE Z6 μου χρησιμοποιώντας Tapatalk
Originally posted by kos25k View Postthanks bro.do you use latest 9.0.2 coreelec?also another critical question..will i be able to stream audio through bluetooth to bt sound devices?
Don't know about Bluetooth as I don't use any...
Originally posted by kos25k View Postit finaly booted, etcher made the trick! but can someone please tell me how to install netflix? i made some steps but i am really lost. it says to check my credentials, but i assume they are correct..
For NF addon to accept your credentials first don't use any special characters, just letters and numbers (adjust your credentials on Netflix web site). Also before you try to login check that nobody else is logged in at the same time. The addon works only if maximal 2 users are logged in, so if you try as third user it will not let you.
One more thing, after NF addon is installed, you need to restart the box. After restart wait until you see "Netflix background service started" in top right corner of the screen. Before that you cannot login to your account.
Hi Guys,
We have come up with a kind of pre-configured Kodi based of Netflix. It will also let you run Kodi seperately on the same device. I hope it helps anyone just wanting Netflix. Gives a great picture. Reccomended for L1 devices, so ATV Certified but perhaps not Netflix certified.
Let me know thoughts and maybe if its liked we can let the community continue. It definitlely could use a more slimmed base version of Kodi and a more bespoke interface, although we want it light weight too which is why we steered away from titan Bingie as a base skin.
Is there a fix? I am logged in and can see my accounts, just constant errror
There are currently 3162 users online. 1 members and 3161 guests.
