Netflix in HD is being killed in some of the Chinese boxes.
Originally posted by Davvid View Post
Originally posted by eagleeyetom View PostIt appears that not Netflix, but Google severely wounded our Mecool boxes. All my apps that used DRM stopped working. At once, all of them! I'm afraid that the only solution is pushing Videostrong to pay for certification. The chances of success are slim, though. I hope that I'm wrong and everything will be back to normal shortly.
Videostrog now only advertizes its products as supporting Youtube at 4K, which is a tad pathetic, imho.
Originally posted by Snakx View Post
with "new custom prop"
ro.build.description=once-user 6.0.1 MHC19J 540 release-keys
ro.build.product=once
ro.product.manufacturer=Xiaomi
ro.product.brand=Xiaomi
ro.product.device=once
ro.product.model=MIBOX3
ro.build.id=MHC19J
ro.build.display.id=once-user 6.0.1 MHC19J 540
ro.nrdp.modelgroup=XIAOMIM12TRIAL
Originally posted by erikalara View Post
Do you mean that changing buildprop as you suggested above, you managed into fooling Netflix ATV that it is actually a Xiaomi box and not Mecool (without bricking it)?
Envoy? de mon XT1562 en utilisant Tapatalk
Sorry for my badly english
Mycanal work with magisk and magiskhide prop config with this buil.prop change. netflix ATV don't work but netflix smartphone work and in HD i think.
with "fingerprint" the first choice
ro.build.fingerprint=Xiaomi/once/once:6.0.1/MHC19J/540:user/release-keys
ro.build.id=MHC19J
you said "...netflix smartphone work and in HD i think" could you do a "test pattern" in Netflix app to be sure it's HD ?
Thanks in advance.
nb: in case of just type "test patterns" in Netflix search bar ...Last edited by Mazer.one; 14 December 2018, 15:33.
Originally posted by Snakx View PostYes but with magisk and magiskhide prop config module. It's possible to deactivate in recovery. But work in Netflix for tablet/smartphone
Perhaps we should try get an original Nvidia Shield 7.1 buildprop - which is fully licenced -and 'port' it on our poor Mecool box....(?)
ps: Xiaomi is stuck on 6.01 isn't it?
I can use the smartphone version of Netflix without any prop changes. And by the way I got rid of supersu and installed Magisk too.
Could you tell me which version of netflix you are using?
The last smartphone version working for me is Netflix 4.16.3 build 15172 and it's not HD...
Yes. Can we use ShieldTV's config to patch to our Box?
# begin build properties # autogenerated by buildinfo.sh ro.build.id=LMY47D ro.build.display.id=LMY47D.35739_609.6420 ro.build.version.incremental=35739_609.6420 ro.build.version.sdk=22 ro.build.version.codename=REL ro.build.version.all_codenames=REL ro.build.version.release=5.1 ro.build.date=Thu Oct 8 13:57:46 PDT 2015 ro.build.date.utc=1444337866 ro.build.type=user ro.build.user=NVIDIA ro.build.host=mobile-u64-396 ro.build.tags=release-keys ro.build.flavor=foster_e-user ro.product.model=SHIELD Android TV ro.product.brand=NVIDIA ro.product.name=foster_e ro.product.device=foster ro.product.board= # ro.product.cpu.abi and ro.product.cpu.abi2 are obsolete, # use ro.product.cpu.abilist instead. ro.product.cpu.abi=arm64-v8a ro.product.cpu.abilist=arm64-v8a,armeabi-v7a,armeabi ro.product.cpu.abilist32=armeabi-v7a,armeabi ro.product.cpu.abilist64=arm64-v8a ro.product.manufacturer=NVIDIA ro.product.locale.language=en ro.product.locale.region=US ro.wifi.channels= ro.board.platform=tegra # ro.build.product is obsolete; use ro.product.device ro.build.product=foster # Do not try to parse description, fingerprint, or thumbprint ro.build.description=foster_e-user 5.1 LMY47D 35739_609.6420 release-keys ro.build.fingerprint=NVIDIA/foster_e/foster:5.1/LMY47D/35739_609.6420:user/release-keys ro.build.characteristics=tv # end build properties # # from device/nvidia/soc/t210/system.prop # # opengles.version is 16.16 (maj.min) fixed point ro.opengles.version=196609 persist.tegra.nvmmlite=1 persist.wlan.ti.calibrated=0 ro.sf.override_lcd_density=1 # glcomposer composition persist.tegra.compositor=glcomposer persist.tegra.decompression=cde-client # WAR for bug 1536227: Restrict all ZBC clears to transparent black: persist.tegra.AF73C63E=0x80007ffd # disable input resampling ro.input.noresample=1 #enable Miracast game mode support nvwfd.gamemode=1 #max resolution supported for Miracast is 1080p, represented interms of macroblocks nvwfd.max_macroblocks=8160 # usb vendor and product ID definition ro.nv.usb.vid=0955 ro.nv.usb.pid.mtp=B430 ro.nv.usb.pid.mtp.adb=B431 ro.nv.usb.pid.rndis=B434 ro.nv.usb.pid.rndis.adb=B435 ro.nv.usb.pid.ptp=B432 ro.nv.usb.pid.ptp.adb=B433 #Set audioflinger resampler quality to DYN_HIGH_QUALITY af.resampler.quality=7 # # from device/nvidia/platform/t210/system.prop # wifi.interface=wlan0 wifi.Xinterface=xlan0 ap.interface=wlan0 # boot animation property persist.bootanim.preload=1 #pbc properties pbc.log.on=0 pbc.hist.size=5 pbc.step.period=700 pbc.polling.period=100 pbc.throttle.depth=0 persist.sys.pbc.enabled=1 persist.sys.pbc.hyst=5 persist.sys.pbc.psys.cap=10000 persist.sys.pbc.ibat.cap=4000 persist.sys.pbc.pbat.cap=30000 persist.sys.pbc.inf.game.mode=1 persist.sys.pbc.inf.socthres=20 persist.sys.pbc.pbat.slope=1.5 persist.sys.pbc.pbat.intercept=-7 persist.sys.pbc.over.cfboost=true persist.sys.pbc.cfboost.floor=800000 persist.sys.pbc.gfboost.floor=300000 #disable Eco mode with charger persist.sys.NV_ECO.IF.CHARGING=false #playback type device, for cec ro.hdmi.device_type=4 #used to enable adb over tcpip on port 5555 from Settings app persist.system.adb.tcp.enable=0 # # ADDITIONAL_BUILD_PROPERTIES # persist.sys.media.avsync=true dalvik.vm.heapstartsize=12m dalvik.vm.heapgrowthlimit=128m dalvik.vm.heapsize=448m ro.build.version.ota=2.1(22.18.61.16) drm.service.enabled=true ro.setupwizard.mode=OPTIONAL ro.com.google.gmsversion=5.0_r2 ro.com.google.clientidbase=android-nvidia ro.sf.lcd_density=320 ro.nrdp.modelgroup=SHIELDANDROIDTV ro.nrdp.audio.otfs=false ro.radio.noril=true ro.tegra.tz3.sorting=1 persist.sys.dalvik.vm.lib.2=libart.so dalvik.vm.isa.arm64.features=default dalvik.vm.isa.arm.features=div dalvik.vm.dexopt-flags=m=y net.bt.name=Android dalvik.vm.stack-trace-file=/data/anr/traces.txt
Originally posted by mralexkungYes. Can we use ShieldTV's config to patch to our Box?
Apart from that, I'm afraid we need a developer to tell us which parts can be replaced in the prop...or the box won't boot up (?)
Mhhhh...can you upload it as an attachment file? The alignment isn't quite right here...
Apart from that, I'm afraid we need a developer to tell us which parts can be replaced in the prop...or the box won't boot up (?)Sorry for my badly english
ps:I have not tried the method and I am not responsible in case of brick of your box ...
The "ShieldTvBuildPropOriginalPost.txt" in attachmnents is the original post by mralexkungLast edited by Mazer.one; 14 December 2018, 16:17.
The new Play Services and Google servers are now making Chinese boxes difficult to be compatible on TV and streaming apps.
i don't use L1 DRM apps, but as of late noticed Google has changed Web view services. It affects all devices. You must upgrade your Web view by freezing or uninstalling chrome, or Chrome Dev. At this time if web view is frozen or disabled by chrome browser, apps may break.
In fact i had to remove Web view completely and copy it into the system priv-app folder.
This is one issue of many Google is doing to break our boxes.
i have lost 3 apps from operating as before the new Google system updates. Those apps are for phones and use some Web view trickery with playback. I assume a new firmware to correct Web view is needed to be compatible with the latest Web view.
There are currently 3177 users online. 0 members and 3177 guests.
