New Nextbook - Next7HD8G aka NX007HD8G - Root and Romdump Wanted
Originally posted by jeremey989 View Postit was stock. but i had rooted it already with the cydia impactor. now when i plug the tablet into the computer it looks for the drivers for m6-chip
Is your tablet still not powering on at all? You can't boot normally or boot to stock recovery, even with the power cord plugged in?Freaktab Rom Developer
Originally posted by shaunmt View PostIt should not be possible to brick a tablet unless you've flashed an incompatible update or used some sort of USB flashing tool to erase the NAND.
Originally posted by jeremey989 View Poststill won't power up. i really messed up somewhere.
I have noticed with these Nextbbook they can get stuck in fel mode. My 8HD actually goes straight to it when it shuts down using the power off in the OS. Once it does this it is kind of hard to get out.
Try this.
1. Put the tablet on the charger for about an hour, just to make sure it has juice.
2. Connect the tablet to the computer via usb. Don't press any buttons on the tablet just listen for the connect sound on the PC. Check the device manager to see if anything popped up.
3. If no noise keep the tablet connected to the PC, press and hold the power button for a good 60 seconds, release and do it again. Listen for the connect sound, check the device manager for a new device.
4. If still no device try unplugging the USB. Press and hold the power button and insert the USB, look for a device to pop up M3 in the device manager.
Originally posted by Rabid1 View PostI have noticed with these Nextbbook they can get stuck in fel mode. My 8HD actually goes straight to it when it shuts down using the power off in the OS. Once it does this it is kind of hard to get out.
Try this.
Try this.
4. If still no device try unplugging the USB. Press and hold the power button and insert the USB, look for a device to pop up M3 in the device manager.Freaktab Rom Developer
Originally posted by jeremey989 View Postit comes up as M6-CHIP
ShaunMTFreaktab Rom Developer
Awesome it means you are not hard bricked. Before you try anything else, press and hold power until the device disappears. That way you know you are off.
Originally posted by shaunmt View PostThanks for sharing some new ideas! Your description sounds kind of how mine acts sometimes after I try to boot a test recovery that fails.
If we can't get somebody to provide a ROM dump by next week maybe, I can pick one up from Walmart just to dump.
Originally posted by Rabid1 View PostAwesome it means you are not hard bricked. Before you try anything else, press and hold power until the device disappears. That way you know you are off.
I think we discussed it a little on PM about it wanting to boot into flash (fel) mode. I thought it might be your or my rom or the recovery or some combination, but it looks like it is just a design flaw in the tablet themselves.
Originally posted by shaunmt View PostI thought about doing the same, but I don't have the extra cash for another toy right now. I also thought about picking one up, dumping it and returning it, but I'm planning to exchange my Next8HD8G and I think they limit returns/exchanges these days.
ShaunMT
Originally posted by jeremey989 View Postthe flash tool looks like it flashes an upgrade image file. but does that mean it flashes the recovery also? because its not booting into recovery with the modded on on my external sd
You're tablet is not currently booting anything, correct? No system, no stock recovery, no SD card recovery, nothing?
Does ADB work? does the backlight even come on?
Originally posted by shaunmt View PostI am under the impression that it can flash individual partitions or everything, but I don't know what format the files need to be in. It should also be able to format and partition the NAND if necessary, but again I don't know how to configure or use it.
ShaunMT
There are currently 2699 users online. 1 members and 2698 guests.
