New Nextbook - Next7HD8G aka NX007HD8G - Root and Romdump Wanted
    after searching high and low for roms and firmware. i came across one thread that mentions unsoldering and resoldering the battery. so i opened up the tablet to see if the pictures were similar. and discovered on the battery a sticker that says yifang m7000nd . could i possibly use the firmware marked for the chinese model?
      A large number of these cheap tablets are actually made by Yifang and resold under many different names. Have you found another tablet that you think is the same? A lot of us here would like to know about, as the ROMs are often interchangeable, assuming the hardware is identical.
      I'm sure several of us would also like to know how the dissasembly went and photos would be nice too! Was the case easy to open? I've never tried it on any of mine.
      ShaunMT
      Freaktab Rom Developer
        If you got to Made In China it shows that model as the Nextbook so if you have a link to the factory rom it should work.
ID:	430804Click image for larger version
ID:	430805Click image for larger version
ID:	430806Click image for larger version
ID:	430807Click image for larger version
ID:	430808Click image for larger version
ID:	430809Click image for larger version
            [ATTACH=CONFIG]3351[/ATTACH][ATTACH=CONFIG]3352[/ATTACH][ATTACH=CONFIG]3353[/ATTACH][ATTACH=CONFIG]3354[/ATTACH][ATTACH=CONFIG]3355[/ATTACH][ATTACH=CONFIG]3356[/ATTACH][ATTACH=CONFIG]3357[/ATTACH]
            taking it apart was fairly simple. lightly pried the casing near the hdmi port. got my thumbnail into the opening between the casing and screen. dragged along the seam and popped the clips.
              Thanks for sharing!
                PLEASE HELP ME PLEASE
                Originally posted by shaunmt View Post
                I noticed Wal Mart has another new Nextbook. The model is Next7HD8G or NX007HD8G. This looks like a 7 inch version of the Next8HD8G or NX008HD8G.
                Here is a link to the device at Wal Mart: http://www.walmart.com/ip/Nextbook-NX007HD8G-with-WiFi-7-Capacitive-Touchscreen-Tablet-PC-Featuring-Android-4.1-Jelly-Bean-Operating-System/23711117
                If anyone gets one of these, let me know and I'll help you root it. Give me a romdump and I'll make a modified 3e recovery, stock ROM and root package for it.
                ShaunMT
                I JUST GOT THIS AND THE WIFI DOES NOT WORK CAN YOU HELP ME TO ROOT IT PLEASE IM BEGGING YOU SO I CAN GET THE WIFI TO WORK I CANT FIND THE UPDATE FILE FOR IT ITS NOT EVEN ON THE WEBSITE PLEASE HELP ME TELL ME WHAT TO DO TO GET THIS TO WORK
                  CAPS REALLY AREN'T NECESSARY...
                  There are no official updates available. Neither the vendor nor the manufacturer even provide a copy of the original firmware.
                  If you've got a brand new tablet and haven't yet tried to flash anything, and your WiFi doesn't work, then you very well may have a defective device.
                  If you have flashed something that didn't work right, then you might want to try the files available here:
                  http://www.freaktab.com/showthread.php?7011-Amlogic-Next7P12-8G-Modified-Recovery-Stock-Rom-amp-Flashable-Root
                  The ROM posted there offers no new features or fixes. It is simply a copy of the original ROM dumped from a working device. The modified recovery is just like the stock recovery only it allows you install packages signed with Google test keys instead of Nextbook keys. The root package will root the tablet.
                  ShaunMT
                    ShaunMT
                    I bought one. I'd really like to install Kali Linux on it, but I'm still learning. I would like to root it first. What do I do first, hombre?
                    P.S. I'd be happy to give you a romdump, except in the thread on how to do it you recommend onandroid, which requires that the device be rooted. Did I miss something?
                      Awesome! Cydia Impactor should root it for you. After you root it, please dump the ROM before doing anything else. Here are instructions for dumping the ROM:
                      http://www.freaktab.com/showthread.php?7768-How-To-Dump-The-Stock-ROM-from-an-Amlogic-Based-Nextbook-Tablet
                      ShaunMT
                        ShaunMT
                        Yeah, I can't find any meaningful info on the problem I'm having with Cydia. It can't detect my device. At first I thought it was a driver issue, but I can't get it to respond after having tried to update the drivers (they were current). The Cydia Impactor homepage provides little help. Any ideas?
                        EDIT: Got it. had to turn on developer options and allow usb debugging
                          Dump Incoming. Have to go get an SDcard. (:
                            Glad to hear it!
                              Yeah... you'll be wanting an external SD card. Don't skimp on a cheap one either... they tend to wear out very fast. Spend a little more for a name brand one, rated class 10. A name brand one can probably be expected to outlive the device you buy it for.
                              I got a 32GB Class 10 SanDisk brand micro SD card from Amazon. I think I paid around $30 for it.
                              ShaunMT
                                Ok, new problem:
                                Now when I try to get Onandroid to do the backup I get an exit (code 70) Whether I'm using the default shell or not. Anyone have this same problem?
                                Edit: It's Alive!
