New Nextbook - Next7HD8G aka NX007HD8G - Root and Romdump Wanted
    Alright Shaun, where do I go to input the dd part of this? Is it part of Onandroid (I hope) because it looks to me liike it's command line type stuff for linux...which I'm not so well versed in. In other words:
    Where do I type "cat proc/mtd", etc? I'll be digging while I await your reply.
      You need to download a terminal app to type those commands into.
      I'm researching your other issue with Online Nandroid Backup... I don't remember having to install anything for it, but I think I may have updated something before I tried to install it.
      ShaunMT
      Freaktab Rom Developer
        This might be the coolest thing I've ever done, Shaun. I just want you to know that.
          When I get to the dd section I'm told permission is denied. I have clockworkmod's superuser app. Is there something in particular i need to do before it will allow me access?
          Edit: Got it. Same as old Linux.
            Enter su on a line by itself. You'll be prompted to grant access to your terminal app.
            ShaunMT
              Ok, new problem:
              Now when I try to get Onandroid to do the backup I get an exit (code 70) Whether I'm using the default shell or not. Anyone have this same problem?
              Edit: It's Alive!
              You need to go to settings in Online Nandroid Backup and install the onandroid script and mkyaffs2image.
              You'll also need to change the backup location to your external SD card, and select save Yaffs2 as Tar.
              ShaunMT
                You'll also need to change the backup location to your external SD card.
                ShaunMT
                Good to include this for those who follow.
                I have the .zip file. Where do you want it?
                  The instructional thread has already been updated...
                    Well, The upload is at 3%...I'm going to go do some calculus problems for a few minutes. You should have your link soon enough!
                      I'm in no hurry. I won't be able to do anything with for a while. You can PM me the link when it's ready and I'll let you know when I've downloaded it so you can remove it.
                      Thanks for helping out and enjoy your rooted tablet!
                      ShaunMT
                        did it work??
                        Just got this tablet:
                        Nextbook 7
                        Model: NX007HD8G
                        Serial no.: YFG0813030189
                        Android: 4.1.1
                        Kernel: 3.0.8
                        Build: JRO03C.v008
                        Were you guys able to root it??
                        If so can you please provide me with a link??
                          Need ROM
                          Cydia Impactor rooted my NX007HD8G on the first try. But then I foolishly fiddled with some system files and ended up with the left 60% of the screen black. It still responds to touches, but I have to guess what I'm touching. Factory Reset dumped all my apps, but didn't affect the display. I sure could use a flashable stock ROM package!
                            Re: New Nextbook - Next7HD8G aka NX007HD8G - Root and Romdump Wanted
                            I think I have a dump for this laying around some where. I will check and upload it tonight.
                            Sent from my SPH-L710 using Tapatalk
                              Will this dump be rooted?? All I need is root the tablet to move game data
                                It will be the same format as I posted for the other models, a modified recovery, a non-root stock rom, and a root patch that can be flashed by itself.
                                ShaunMT
