[ROM] AlfaWise H96 PRO+ EyeTV ROM - AndroidTV ARM64 - my first release TWRP only
Originally posted by natzen View Postje rajoute 6play version android tv bbox aussi ne fonctionne pas ...le seul firmware android tv qui ne contient pas ces bugs c'est celui ci (si ça peut aider à patcher)
http://4pda.ru/forum/index.php?showt...ost&p=77250507
Originally posted by bullgates View Post
Hi natzen ,although I understand almost everything in French, I'm not so comfortable to write it, so here it goes in English. I did some tests with Amazom Prime, the normal sideload apk will not work properly, but this one does and also integrates in Leanback. I also do not have netflix, but from what I could see it should be the same. But thanks for the link of the ROM, I'll see if I find any mod that can help in that. Just give me some time as I don't have much time right now. Merci bien pour le addresse de la ROM!
Originally posted by huijianwuxin View PostHello,
Can the tv remote wake the box up via hdmi cec? Tried other roms in which I can only send it to sleep but not wake it up. Thank you. Really appreciate your hard work.
Originally posted by X92-2GB View Post
Either it's the TV or the cable. Every H96 pro plus firmware I have ran works fine for my 2008 Samsung TV.
I use samsung tv as well. CEC works perfectly fine on my shield tv. But on h96 pro plus, when I use the tv remote to turn the tv on, h96pro will not wake from sleep state. I can only use the h96 remote to turn it on. I use superceleron atv scv4a.
could be your hdmi cable.
Donno, maybe the lpddr3 v6 boards work with CEC better. Never had an issue with powering on tv from waking box from sleep and sleeping when turning off tv from tv remote.
The problem is that I cannot update from the stock firmware. Tried in twrp it shows that "signature verification failed,installation aborted".....I have a blue pcb lpddr version.Last edited by huijianwuxin; 01 October 2018, 02:03.
Hi all, I have a box box h96 pro 32gb 3 ram, I'm on the rom 7.1.2 SCV7A, I wanted to be using this rom, the important dpra me is a good image to watch netflix, iptv, youtube, your rom Are you good at it? It pays to leave the rom that I'm using SCV7A, To use yours? Thanks in advance for your feedback.
There are currently 2735 users online. 2 members and 2733 guests.
