[ROM] AlfaWise H96 PRO+ EyeTV ROM - AndroidTV ARM64 - my first release TWRP only
Originally posted by alves_1983 View Post
Originally posted by alves_1983 View PostHello friend, I installed your rom via twrp, normal startup, but you could not put the iptv list in the perfect player, not even in your iptv application of rom, store netflix does not catch, many errors, I came back to SCV7A.Last edited by bullgates; 06 October 2018, 10:26.
a bom, tava usando o traductor, entao, instalei a rom e instalo normal, só que logo no inicio abaxei p perfect player aplicativo que gosto de rodar a lista iptv e não deu certo, simplismente diz que não existe atualizacoes, o net flix da loja não pega da erro, eu acho que abaixar pelo chrome deve da certo, bom eu nao tentei, esses 2 erro foi o que notei de inicio, nao testei por um grande tempo, eu queria uma rom diferente melhor que SCV7A, MAIS ACHONQUE NAO TENHA, essa é muito boa.
Originally posted by bullgates View Post
Just delete the data of the application HappyCast, this version if used over the previous will give that error if no factory reset is done. Please tell me if it solved for you. Thanks.
Hello, installed on my H96 pro wisdom version, the blue and red leds (on/off) doesn't work, they are off all time, and I can't power on after shutting down, just to wake up from sleep mode.
And the navbar and notification bar doesn't appear, I'm using an air mouse, tried to do like normal android but nothing happens.
I just use V1.05 on my LPDDR3 H96 Pro + and find 2 bugs
1. when I use "adb connect" to the box, it should have a certificate-allow message but just show SystemUI crashed
2. using YouTube 4K videos, the voice does not sync and delayed
BTW, I can use G5 USB Voice Air mouse remote control perfectly and trigger voice search directlyLast edited by HiTony; 18 January 2019, 08:26.
This is my new fav build! Seems to be far more stable then SV4A SuperCeleron build ... All of my apks work great, Smarter YouTube app runs perfect.
Notes:
-Under accessibility I increased the cursor size for the TV
-Auto Detect TV res made the screen too wide, had to manually select 4k 30hz or whatever.
Thank you so much, I do not use any of the IPTV stuff, but as a solid rom for apk or kodi, this is very good...
There are currently 2066 users online. 1 members and 2065 guests.
