But I am confident that there is a problem somewhere in my SDK.(probably uboot) Because I succeeded to make it wake one time! (I pressed remote power button and after seeing logs, Amazingly the exit_reason was 2 (i.e. BT_wakeup!!!) However after that resume no longer works! Just for first time it wakes and with exit_reason of BT!)
Wake up on IR remote not works
To add a note: I think the problem is not around IR and its drivers. My box does not wake up from suspend or poweroff from any source;neither HID nor IR remote or anything else!
Originally posted by bumerc View PostI meant compiler. To compile uboot, which compiler do you use?
Full version is pasted here
P.S. I used uboot from 3 sources. (my own sdk, stane1983 github, khadas github) but they make no difference in result.Last edited by salehdeh76; 10 September 2018, 13:30.
Another interestig point:
When I run this command:
Code:adb shell input keyevent KEYCODE_POWER
Originally posted by bumerc View PostTo build the BL301-FW you need strictly „arm-none-eabi-„ toolchain.
CROSS_COMPILE=arm-none-eabi-
(I have already arm-none-eabi- on my system with no problem)
What should I do about this? Investigating device tree against correct ones (from other boxes) I think the problem is in BL301 and/or scp_task/power_ctrl.c .....
Originally posted by bumerc View PostI do not think so. This FW I tested successfully on several devices p212, q201, it works fine. Try LibreElec or CoreElec on SD card and see if it works there.
Is it possible that the problem is from uboot's devive tree? As you know there is some *.dts files in uboot/arch/arm/dts . If I copy my kernel's dts to this and add enough config to uboot/arch/arm/dts/Makefile, then can uboot understand my remote maps, etc? bumercLast edited by salehdeh76; 18 September 2018, 09:34.
There are currently 2796 users online. 0 members and 2796 guests.
