MECOOL KM9 Android TV Voice Remote Amlogic S905X2 A8.1 4/32 Dual Wifi Fast lan BT4.1
SOME QUESTIONS AND ANSWERS:
I've been playing with the MECOOL KM9 Pro Deluxe for a few days. - I'm very happy with the playback quality Very smooth. I'm running a very basic setup - wifi - TV Plugged into HDMI - External Amp plugged into TV.
Reading through the forum, there were one or two people that asked how to bring up the task manager to close background apps. A few suggestions of apps were made.
I always run with a cordless keyboard/mouse combo. Simply press Alt-Tab. That switches to the Task Manager. Holding the Alt Key down, use your mouse to close all background programs.
Another few members here, mentioned their USB 2 Port wasn't functioning. DO NOT DO THIS - if you go to advanced settings, Display, there is an option USB Mode. There are two radio buttons - host and device. Selecting either of these will disable the USB 2 Port. YOU CANNOT switch it back on (I haven't found a way, perhaps someone else knows). The only way I got it activated again was to reset the box to factory default. So don't try this - stay away from the option.
A few members mentioned the ChromeCast (Built In) doesn't work either. I have not had any issues. I can cast my YouTube or Google Gallery photos and videos from my Phone without any hassles.
Can anyone recommend a Bluetooth game controller for this box? Something under $30 preferred.
Also, I just noticed I've lost the dual band wifi option, under available connections I had 2.4 & 5G. Now only the 2.4 is available, which is intermittent at best.Last edited by SJMoore; 30 December 2019, 04:08.
I am kind a new to ATV flashing. I flashed phones and tablets before though. So can I just take any rom to flash, as long as it for the S905X2 device? Or should I stay to specific rom's for the Mecool KM9?
Also I see a lot of roms in the download section. Can anyone advise me a good one?
One last question: What is the difference between the KM9 and the KM9 Pro? They seem identical on the hardware side.
Originally posted by razzor View PostIs CoreElec work with this box properly?
Originally posted by exotic34 View PostHello friend..
KM9 Pro firmware here ....
PI.V1.20190329 release-keys
https://androidfilehost.com/?fid=1395089523397954434
Thanks to a friend of Manhhung ..
I need your help please if you can give me a good tested software update "mecool km9 franklin user debug api v1 20190220.151755"
like this
https://www.amazon.com/dp/B07PXJD3T6..._-j4PCbQX8C8FX
can fix the screen mirroring for this tv box and work withe voice remote like
and thank you again
Honestly, i'm completely lost in the versions of KM9's and its derivates. I need some help upgrading my KM9 4/32Gb (w/ voice remote) on Android 8.1. Which is the latest and reliable compatible firmware? I bought the necessary cable, i've done many custom firmware updates on my phones but i guess i need a good set of instructions for this.
Any help would be highly appreciated.
I confirm coreelec works with mecool KM9. You need IR controller for configure and pair your original bluetooth controller. You can't boot the device with your bluetooth controller. I play most Netflix videos in 1080p, but some videos only play in 540pLast edited by N0ob; 22 June 2020, 17:45.
https://mega.nz/file/2VVmzCDT#ASQkwR...Z7rKjn9ojZJliI
The above works according to some user from KM3 thread up to 4k for netflix
i would love some help i have 2 mecool km pro boxes and i wish to use my minix a2 lite and/or my minix a3 remote . unfortunately the back key does not work with either remote or either box.
i cannot even see the remote conf on the boxes so dont know what to do. the back key works with kodi as i modified the keypad.xml.
i was thinking of buying an mx3 with voice and keyboard but am afraid i will face the same problem
anyone have any experience with this
thanks in advance
There are currently 1793 users online. 0 members and 1793 guests.
