MECOOL KM9 Android TV Voice Remote Amlogic S905X2 A8.1 4/32 Dual Wifi Fast lan BT4.1
Originally posted by frenkovka View PostAfter flashing my KM9 with this image, box has a very poor reception of signal from remote device (with voice control). I have to point the remote directly to the box when with the previous I could point it away and the signal would be recieved still.
Can anybody assist how to fix this issue?
Originally posted by simbian View PostHello, i received this tv box from Gearbest with Android 9 already installed, i suppose the latest official firmware available.
I have problems using VPN services with my IPTV subscription.
I tried several both free and premium VPN apps, they works well and connect to VPN servers but when i start the IPTV apps the channels does not load.- It isn't a VPN related problem, because they connect fine using their apps (eg. i tried NordVPN), the problem is only when using my IPTV list.
- It isn't an IPTV provider problem, they confirmed me that VPN is open and allowed, i did a test and the same list works well using VPN services in another device (i tried a smartphone with Android 8.1 Oreo) and connected to the same WiFi home network.
- It isn't an IPTV app player problem, i used the same IPTV apps (Gotit, Extreme IPTV...) used in the tv box in the smartphone with Android 8.1 Oreo and it works well using VPN.
This is working for me but a bit of a hassle every time. Has anyone found a fix for this bug?
if you talk about the trick of YABLIO the link is here : https://drive.google.com/file/d/1Wek...7JKaiz5Nq/view
with this other : https://drive.google.com/file/d/1RGQ...AMcpSjk-p/view
install the 2 APPLICATIONS
launch the first application black background to log
and there is OK on KM9PRO too
And see the youtube video for the manipulation
Originally posted by dangchui View Postif you talk about the trick of YABLIO the link is here : https://drive.google.com/file/d/1Wek...7JKaiz5Nq/view
https://www.youtube.com/watch?v=8esZpLrJwI8
Originally posted by dangchui View Postwhat is your box KM9PRO OR KM3 i repeat this trick is ok only on box certified not the KM9 Simple for exemple
if you have install the two apk you launch only the black apk yablio and verified you have not other version of netflix installed
I have the mecool km9 that comes with IR remote and no official android TV.
I have a strange issue with the device. Whenever I turn it off and back on, system time is set to January 1, 2015.
It can't sync the clock through the internet. It's connected via the Ethernet port and the auto time sync setting is on.
The time problem causes apps to believe they are not connected to the internet so nothing works unless I set the time and date manually.
There are currently 4000 users online. 3 members and 3997 guests.
