MECOOL KM9 Android TV Voice Remote Amlogic S905X2 A8.1 4/32 Dual Wifi Fast lan BT4.1
Originally posted by clarkss12 View PostMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
#526.1Guest commented19 February 2019, 20:19Editing a commentWell, it's true that we mainly get updates from the online retailers (e.g. http://blog.geekbuying.com), not over the air. With the Amlogic SDK 9.0 now just coming out of beta, I'm hopeful that any box based on the Amlogic u211 reference board will have a promising future...and the KM9 is still the only one with Widevine L1.
Guest, I hope you are correct about they will push Android PIE to some of these boxes. Right now, for my purposes, the KM9 is useless...... It will play almost all the video Codecs available today including the HEVC 4k videos with high bitrate (but not with the 100 Ethernet connection) with the 5Ghz WiFi band. However, as with most of these boxes, it will NOT play any HD audio, but will play Dolby Digital and DTS. I am not sure if it will play videos encoded with VC1, since most of these boxes wont play it without tons of dropped frames. So, for my system, with a mid range Yamaha AVR, I like to hear the HD audio. Also, none of these boxes support automatic framerate, switching, even using Kodi.
The biggest issue for me, is that this KM9 will NOT play Plex OR Emby, which is a non-starter for me. Also, there is no LibreELEC or CoreELEC for it. I can't remember if it has a locked bootloader.
Guest
Funny, I haven't had any video codecs that have been a problem yet, but I primarily play x264 with stereo AAC. I've also been running exclusively on Ethernet without issues. My multi-channel audio I tend to just pass through to my AV receiver. You have to change the defaults for that in Kodi, but so far it's been working fine.
I've only seen one of these off-brand boxes (the Zidoo X7) that had a locked bootloader. This one is not factory rooted, but the bootloader is unlocked and they're using the Amlogic test keys. That's allowed me to create a signed TWRP OTA update. From there we can do practically anything (as long as it doesn't involve keys in secure storage).
The KM9 hardware is pretty ideal, and it's even got a reset button. I really just wish that Xiaomi would update the Mi Box to use this latest Amlogic reference board.
Originally posted by Magendanz View PostFunny, I haven't had any video codecs that have been a problem yet, but I primarily play x264 with stereo AAC. I've also been running exclusively on Ethernet without issues. My multi-channel audio I tend to just pass through to my AV receiver. You have to change the defaults for that in Kodi, but so far it's been working fine.
This is using version OPM1.171019.11 V0828.20181122. I keep swapping firmwares, so not sure this is your modded version.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by MagendanzThe MAC and serial number are written to secure key storage at the factory, so they should survive flash of an OTA update or AML burn package. Is there a chance you selected something other than the defaults in USB Burning Tool? If you choose the option to "overwrite key" that might have caused you to lose the factory settings.Last edited by Guest; 20 February 2019, 01:49.
In my humble opinion, the Mecool KM8 is a better buy for around $56 USD. Everything seems to work, except Netflix in HD (which you said you don't need), and no Amazon Prime video (so I heard).
My video on this device >> https://www.youtube.com/watch?v=LygWfEJZ7N0&t=1233s
The Mecool KM9, for me is a backward step from the KM8, and that is probably because of the newer SOC. It is OK for basic usage, but won't play some of my major apps like Plex or Emby. The Bluetooth voice remote, keeps loosing the connection, so I have to continually pair it.
My review of the Mecool KM9 >> https://www.youtube.com/watch?v=TgneKZ9zBxY&t=300s
The Mecool M8S Pro L with the Bluetooth Voice remote is a very good device also, but does run quite hot.
It really depends on what your external hardware setup is, and what apps you want to use it for. Almost all of these devices will play YouTube in 4k, but most lack in quality audio output. In other words, if you have a nice surround system, and 4k TV, you MAY want to consider the Nvidia Shield. Or dual booting the KM8 with CoreELEC and it plays everything, including ALL of the HD audio codecs.
Running CoreELEC on these inexpensive boxes, you can have Netflix in 720p with DD+.
In this way I can forget KM9 in this moment, unless there is firmware update from either official or 3rd party.
KM8 is in a lower hardware spec, with 2G ram, 16G rom and 2.4G wifi. I am a bit concern whether 2+16 is enough for future use...
Guest
Originally posted by C-Leung View PostIn this way I can forget KM9 in this moment, unless there is firmware update from either official or 3rd party.
Also, I've been unable to build TWRP for the KM8, so you won't be seeing any custom ROMs for it.
I have both the KM8 and two KM9s...and I definitely prefer the KM9. It's noticeably faster and running a more recent version of the OS (8.1 vs. 8.0). While the S905X2 sounds like it may be interchangeable with the S905X, the X2's 850MHz Mali-G31 MP2 is considerably smoother than the old 750MHz Mali-450 MP3. The KM9 also comes with higher bandwidth DDR4 DRAM...and 100% more of it.
If you can get the Emby client to work on this device, I will give it a better grade, but as it is, for my usage, it is not usable.....MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Guest , How do you watch your media on this KM9? Kodi??MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I am afraid not. I have asked for help the developer of the Netflix plugin for Kodi and he could not do something. The device fails the provisioning from Netflix and the plugin does not work. The android apps also cannot start in this device, since Netflix blacklisted it sometime ago...
The only thing you can try is downloading the Netflix app for tablets and phones (the one with the red logo) and try to see if it works, of course this app is only mouse controllable.
Originally posted by Agronur View Posthi guys and girls. can anyone watch netflix on this device?
all atv roms i tried gives error. apps and kodi extension wont work.
i am not asking watching 4k. does apps work or not? if yes how. please help me.
Originally posted by vprasinos View Post
Did some tests today myself to confirm what is being said in here about netflix on this box. The truth is that netflix CAN run on this box but at limited resolution.
I downloaded from apkmirror some of the black backrgound-red logo versions which are for tables-phones and they successfully played content. It is not the best experience ever since the black backrgound-red logo apps are designed for touch control and we have a remote control, so a mouse or a air remote is necessary to plug into usb to control the app. Through the latest app I could see the movies and tv shows I played at 720p or some of them at 540p. The strange thing is that I could see "Polar" at 1080p! I don't know the role of the DRM level to the quality of the stream but seems that some movies have different security requirements and can play L1 content with higher resolution and some with lower. Quite strange...
The white background-red letter versions (ATV versions) did not open at all and they produced a -100 error (that they could not find a proper network or something).
All of the above were tried with the stock firmware which I think it is 201809011.
There are currently 4075 users online. 0 members and 4075 guests.
