MECOOL KM9 Android TV Voice Remote Amlogic S905X2 A8.1 4/32 Dual Wifi Fast lan BT4.1
I'm used to the Tanix TX9pro, to adjust mouse and keyboard settings, you go to Settings/preferences/More Settings/Languages & Input.
Anyway I think my problem is a malfunctioning remote, I cant highlight on any of the apps top border menu tabs using the up & down button.
I switch to the mouse cursor function and it's super slow but does work.
I used a wired mouse as a test, and could navigate just fine.
Hi Guest Is it any news about 20181205 form You? For now http://freaktab.org/c01cf2cd7aa156c2 it's the newset ?
Originally posted by abood250 View PostCan anyone please download latest version of Netflix as apk and try it to confirm that play HD or not and without error message?
This latest version
https://www.apkmirror.com/apk/netfli...load/download/
In application down click on More > Account > playback settings > set high.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by SJMoore View PostReceived the km9 this morning. Not sure if mine is defective, but I can't access the 'more settings' tab to adjust the pointer speed. Tried everything! Where the hell is it?
My version is the regular non-voice remote. It also has Netflix preinstalled, which works well, although I'm not using a 4k TV. Just a 1080 It looks like its running at 720.
Also have issues with a couple of movie apk's (not sure if I can mention them here) they worked fine with Android 7.1 but not with the Km9.
Could you please try newer versions on this link and try to play HD
Edit: What are you looking for??? If you don't have this device, but thinking about getting it, DON'T..........MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Same thing, 960x540, and only mouse control....... I have tried 8 different versions that I have saved, but none worked.......
I can't even flash mine. Even with upgraded USB cable.
There are currently 3615 users online. 3 members and 3612 guests.
