MECOOL KM9 Android TV Voice Remote Amlogic S905X2 A8.1 4/32 Dual Wifi Fast lan BT4.1
Originally posted by Magendanz View PostSo, the WiFi problem seems to be cured when reverting from sparse to normal Ext4 images, indicating that the problem is with file permissions created using make_ext4fs. I'll probably need to make some tweaks to the file_contexts, but until then I've made the normal version of OPM1.171019.011 V0828.20181122 available again here: http://freaktab.org/bc7c6c5797215526
To flash this will be using the Local OTA option?
Originally posted by Magendanz View PostOkay, here's the Amlogic burn package (.img file) for this new 20181122 OEM firmware release: KM9_OPM1.171019.011 V0828.20181122.img
i see there 's new version of firmware on mine in france my version is 2018119
WHAT S news on this version and why is not in OTA online
i suppose the problem for netflix is not resolve
you have flash is suppose with amlogic burning tools in recovery mode
#318.1Guest commented18 December 2018, 08:26Editing a commentI think you're missing a digit in that datestamp. I can only guess what changes the OEM has made, but Mecool ironically doesn't serve OTA updates online. If you run this tool when connected via USB Burning Tool, it will rip the partitions from the device and I can take a look: http://freaktab.org/8ed9a0505c61f6f9
Originally posted by panchovilla View Post
Mine runs all apps alright. Used to run netflix.
Has trouble reading USB.
All my media, movies and TV shows are scattered around my network on NAS's and External HDD connected to my Asus router. My boxes are connected via HDMI cable to my Yamaha AVR then to my Samsung 4k (UHD) TV. I use Emby as my primary media player software, now instead of Kodi. I also use Plex occasionally. Most of my movies are DVD rips that have Dolby Digital and DTS sound tracks, which this box will play in Kodi, but NOT in Emby or Plex.
I have 2 actual 4k movies, and only my Nvidia Shield and Zidoo X9S will play those movies and both devices does automatic frame rate adjustment, and passes through the HD audio.. This box will play the 4k movies using Kodi, but not frame rate adjustment and NO HD audio.
Do you have an AVR for surround sound? Do you have your own media, like movies and TV shows? Do you have a NAS for your media storage?
I only have a soundbar. Optical cable from the tv.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
No probs with the remote at all.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
strange......... I don't think it is the remote, just the firmware. The assistant does not hear me, but using the voice on my cellular phone, she hears me.... I have run into this before on other boxes.......
Guest
Here's an initial build of TWRP 3.2.3-0 for the Amlogic u211 reference board: twrp.u211-3.2.3-0.img
For your convenience, I've also created a signed OTA update that can be installed with the UPDATE app: twrp.u211-3.2.3-0-signed.zip
It's built with the twrp-8.1 minimum OMNI branch and is using a prebuilt GT1 Mini kernel. I've copied source up to the new twrp-8.1 branch in the Amlogic repository for this along with updates for the q201 and p212 reference hardware.
Originally posted by Magendanz View PostHere's an initial build of TWRP 3.2.3-0 for the Amlogic u211 reference board: twrp.u211-3.2.3-0.img
Thank you so much nice work ... What do you recommend for magisk ? Do you work on it ?
Guest
Guest
I've also created an OTA update from this latest burn package, which can be installed using the UPDATE app: KM9-ota-V0828.20181122.zip
Note that I've used my update script, so it will also run in TWRP and can downgrade.
Originally posted by Magendanz View PostI've also created an OTA update from this latest burn package, which can be installed using the UPDATE app: KM9-ota-V0828.20181122.zip
There are currently 1862 users online. 3 members and 1859 guests.
