MECOOL KM9 Android TV Voice Remote Amlogic S905X2 A8.1 4/32 Dual Wifi Fast lan BT4.1
Originally posted by panchovilla View Post
Originally posted by ojerez View Post
Could you explain how to put Netflix in 4k on the KM9? Thank you very much, it may be a reason why I do not return it as it arrives.
MECOOL KM8 Google Certified Android TV Box with Voice Remote - Amlogic S905X Android 8.0 2GB RAM + 16GB ROM VP9 HDR10 Dolby Audio Support Youtube 4K
But even then, 4K will be downscaled to 1080p as the Mecool KM9 doesn't support a 4K frame-buffer for the video, only 1080p.
Only if auto frame-rate switching takes place then the video goes into its own 4K layer, eg. when using the Netflix Kodi addon and your device supports auto frame-rate switching which the KM9 doesn't. The Nvidia Shield is the only Android device playing true 4K Netflix, even the MiBox downscales to 1080p.
Originally posted by ojerez View PostI already have the KM9. The first problem I find is that the Play Store does not update any of the installed app. I installed Netflix from appmirror and it seems that it looks good. This afternoon I will test if it charges 4k. Can you put Amazon Prime Video even in 720p quality?
Thank you
The Amazon Prime Kodi addon can give you 720p.
dangchui panchovilla
I'm using this version on KM9 of Netflix and there is 4k with 5.1 sound and also 1080p with HDR: https://www.apkmirror.com/apk/netfli...-apk-download/
It plays the 4K selections but not showing UHD and 5.1. My Samsung TV's Netflix looks better .
Btw, the app is buggy on mecool M8S Pro L. Keeps saying selection not available at the moment when you select a lot of the 4k movies and shows. But, not on the KM9.
Ronnie, I need that app that shows the resolution of video playing.You may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoLast edited by panchovilla; 05 December 2018, 21:52.
There are currently 2960 users online. 1 members and 2959 guests.
