Enviado desde mi Mi A1 mediante Tapatalk
MECOOL KM9 Android TV Voice Remote Amlogic S905X2 A8.1 4/32 Dual Wifi Fast lan BT4.1
Originally posted by Rakuga View PostYou have to keep pressed the voice command button and talk at the same time. It's different from the phone where you just have to talk. Try this.
Enviado desde mi Mi A1 mediante TapatalkMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
No, I will eat it. Probably toss it into a drawer somewhere......... I can't believe Mecool would dump something on the market like this. Now I see why Gearbest is pushing to get rid of them, by dropping the price.
Originally posted by bajann View PostLol ,that is frustrating (no emby no Plex no Netflix no voice support) ,but do you see any progress on new soc Amlogic s905x2 ?
Originally posted by ezegalli View Post
Plex works, It does have voice support and it?s working. S905X2 runs Android TV Oreo like butterMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
At this time, I don't see any advantage with this new SoC, and I had high hopes for it. I have ONE 4k movie, that only my Nvidia Shield and Zidoo X9S will play (out of my dozens of boxes), and was hoping this new box would play it. But, it won't even play Emby.
Playing a DVD rip and the video is still being transcoded and audio is being transcoded from AC3 to AAC. Video quality is very bad, even for a DVD rip.
One 4k with vc1?I think libreelec(Amlogic s905x s912) will play that .Do you like PQ on nvidia shield?
Here is the info for my 4k movie. It is encoded with HEVC, and not VC-1.
Complete name : \\RT-AC1900P\Seagate_Expansion_Drive\Media\Movies\BlueR ay_Movies\Action\Skyscraper (2018)\Skyscraper (2018).mkv
Format : Matroska
Format version : Version 4
File size : 52.2 GiB
Duration : 1 h 42 min
Overall bit rate mode : Variable
Overall bit rate : 72.9 Mb/s
Movie name : Skyscraper 4K
Encoded date : UTC 2018-10-01 21:17:44
Writing application : mkvmerge v27.0.0 ('Metropolis') 64-bit
Writing library : libebml v1.3.6 + libmatroska v1.4.9
Format : HEVC
Format/Info : High Efficiency Video Coding
Commercial name : HDR10
Format profile : Main [email protected]@High
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 69.1 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.348
Stream size : 49.5 GiB (95%)MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Those of you who have Netflix and or Amazon Prime account can you try to use Kodi add ons on KM9 and share you feedback if it works. You need to have Kodi Ver 18 RC1. For some reason 18 RC2 and RC3 doesnt work to install addons from zip file, just crashes Kodi (it will be great if you can check this too or it just my problem). Check these links for more info
There are currently 5980 users online. 1 members and 5979 guests.
