Sent from my POCOPHONE F1 using Tapatalk
MECOOL KM9 Android TV Voice Remote Amlogic S905X2 A8.1 4/32 Dual Wifi Fast lan BT4.1
Hi ppl. Is possible to control led on this box? I want to turn it off. This is possible on t95z plus box.
Originally posted by rakeshchn View PostHi, Has anyone been able to check the official Chinese Videostrong website or forums to see if they have intentions to keep KM9 up-to-date at least for a little while. The device seems to have a few firmware issues affecting smooth video or audio playback in Kodi and some live tv apps.
The previous model KM8 came with no updates.
If you look at the Beelink S905x2, it already had 9 updates and Beelink regularly posts changelogs here themselves.
So S905x2 with regular updates from manufacturers can be a very good box but without they are no better than any cheap device.
Thanks for info mo123 and Guest
I will not touch that led
Is there some firmware which don't have Wifi 2,4GHz problem? ETH and 5,8GHz working fine, but 2,4GHz is a problem.
Originally posted by aeolous View PostI ve got mine on Friday and first impression is negative ethernet works fine but only 2.4ghz no 5ghz doesn't even show up.
we definitely need an update (mine is 22/11/2018) or else it will be a nice paperweight.
My wireless router is an Asus RT-AC1900P, and a very good router I might add.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Hi ppl. I flashed my KM9 with this fw: https://forum.freaktab.com/forum/tv-...-fixes-and-mod
Now my PC is not recognize my box. How can i back stock firmware?
There are currently 2931 users online. 0 members and 2931 guests.
