MECOOL KM9 Android TV Voice Remote Amlogic S905X2 A8.1 4/32 Dual Wifi Fast lan BT4.1
Originally posted by SJMoore View PostTried that also, no change, stops at 3% everytime, tried 3 Rom's as well, 2 from Magendanz and then tried to put the stock back in, no luck!MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by SJMoore View PostThanks Clark, still not working, now stops at 10% '[10:32:50 919][HUB1-3][Err]--[0x30403003]UBOOT/Partition logo/Download buffer/Data tranfer error'. ughh!
I have swapped multiple firmware's, on this device, the only one that won't install for me is the GT1 mini port from Xannytech.
So, try a different USB port on your computer. Also try a different firmware.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by SJMoore View PostProgress!! finally after about 10 attempts, got it to install successfully, but the version that worked, isn't compatible with my remote (non voice remote) can't get past the scanning screen.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by SJMoore View PostNo other remote is pairing, out of options, I hate to have to go through the Burning process again.
I have a Tanix TX9pro, never had a problem with it. this box...ughhh!MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
What app is that?
Yes, my phone sees the Km9 via BT, but it doesn't have infrared, I'm unable to use it as a remote.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Try the Android TV app. It will pair with your box.
Is there any way to get past that damn screen? anyone have a km9 compatible voice remote they don't need? lol
Tried, app couldn't find the device, but it shows up on my phone under BT paired devices.
Or order one of those $10 voice remotes with a dongle.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Thanks for your input, that's actually the first thing I tried when my remote didn't work, I just can't get out of the remote setup screen, the power button and vol works on my remote, but not when I press vol - & OK together, which is what you have to do to pair the remote.
My only options are, replace the firmware again with the stock 20181205 update from sd card (really don't want to use usb burner pc method after the hassle I had)
or pick up another remote and hope it works, although there's no guarantee in that.
There are currently 2446 users online. 0 members and 2446 guests.
