MECOOL KM9 Android TV Voice Remote Amlogic S905X2 A8.1 4/32 Dual Wifi Fast lan BT4.1
Originally posted by imurreflection View Post
Originally posted by SJMoore View PostAnyone else having issues when running apk's? I have 3 that I run regularly and lately they all crash about 15 minutes into a movie/TV show, (exit to home screen) all Apk's are regularly updated, I'm thinking its an issue with the km9.
Originally posted by rakeshchn View Post
Amazon Prime works fine in 1080p and Dolby Digital plus audio. You need to sideload the correct version of apk as it is not available in playstore. I am hopeful in near future Amazon will release Prime video and prime music apps for Android TV which will be available in Playstore (since Amazon and Google seem to have ended their cold war)
Hi, Thanks for confirming this. Can you please also check if this box is able to play Amazon Prime in 4k. I know that the version required to play Amazon Prime is available on Aptoide. Kindly confirm mate.
I havent been able to get 4K in Amazon Prime, but I cannot confirm if it is because of the KM9Pro or the app. I have the box set to 1080p resolution as it is connected to a 1080p capable audio receiver outputing to 4K TV. Also my internet bandwidth is not fast enough for 4K and I am not even sure if Amazon Prime gives 4K in my country. So too many variables.
What APKs are those? I have KM9 Pro and generally everything run very well. My mostly used apps are Youtube, Amazon Prime, VLC player, Kodi, Thoptv, Jio Cinema & JioTV (India), Tubi TV, TED, Spotify
Problem is with TitaniumTV, CinemaHD and BeeTV.
No issues with Youtube and Smart iptv, they work fine.
Oh..they are vital apk's..did you try apk time to download these apps..you must try Morph and Stremio also..ideally speaking, there shouldn't b any iisues with these apps. Please uninstall and reinstall from apk time
I use "Filelinked" since a long time ago and no any issue,but sometimes their updated late or dead or something else....
Also try "APK Time" too
Terrarium/Titanium/BeeTV/ some of my favorites
Note;and use "REALDEBRID" account as well!!
more fast more FHD links etc.,
and its not expensive,just try it than comment it,I'v been used this account,last 2,5yrs
Originally posted by Duy Tai View PostAndroid TV 9 for KM9. reserved for the box with remote voice
https://androidfilehost.com/?w=files&flid=293435
There are currently 2675 users online. 2 members and 2673 guests.
