MECOOL KM9 Android TV Voice Remote Amlogic S905X2 A8.1 4/32 Dual Wifi Fast lan BT4.1
Originally posted by SJMoore View PostA question...Are there any hardware differences between the two Km9 versions (regular remote/voice remote) or is it simply different firmware?
or this remote......
Originally posted by SJMoore View PostThe remote in the 1st link you posted for the M8SproL looks like the same one that comes with the Km9 w/voice and would probably be the best option for me, since the firmware I installed is for the KM9 w/voice.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Yeah, we've been experiencing regular USB problems with the u211 reference board. It's quite susceptible to EM noise and most of us have had to upgrade our cables. Here's what's worked for me: https://www.gearbest.com/cables-conn...298937892.html
Hi All,
I am newbie in this forum and want to buy a new Android TV box to replacing my faulty RK3368 box. Now I am considering between Mecool M8S Pro L(3+32) & KM9(4+32) .
In most case I would watch youtube or other video streaming app but do not need Netflix.
KM9 is a newer model with ATV 8.1 and 4G ram, while M8S Pro L come with ATV 7.1 and 3G ram. Normally KM9 should be better, but I watched a youtube video and the guy said KM9 is buggy and even not smooth at 1080 video/youtube. It makes me prefer older M8S Pro L more than KM9.
May I get some suggestions from you guys regarding these 2 machines or even other recommended ATV box with similar price?
Thanks for your help!
My video on this device >> https://www.youtube.com/watch?v=LygWfEJZ7N0&t=1233s
The Mecool KM9, for me is a backward step from the KM8, and that is probably because of the newer SOC. It is OK for basic usage, but won't play some of my major apps like Plex or Emby. The Bluetooth voice remote, keeps loosing the connection, so I have to continually pair it.
My review of the Mecool KM9 >> https://www.youtube.com/watch?v=TgneKZ9zBxY&t=300s
The Mecool M8S Pro L with the Bluetooth Voice remote is a very good device also, but does run quite hot.
It really depends on what your external hardware setup is, and what apps you want to use it for. Almost all of these devices will play YouTube in 4k, but most lack in quality audio output. In other words, if you have a nice surround system, and 4k TV, you MAY want to consider the Nvidia Shield. Or dual booting the KM8 with CoreELEC and it plays everything, including ALL of the HD audio codecs.
Running CoreELEC on these inexpensive boxes, you can have Netflix in 720p with DD+.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I noticed after installing Magendanz's Rom, My Mac & Serial number have changed, will I have a problem using the OTA update in the future?
The MAC and serial number are written to secure key storage at the factory, so they should survive flash of an OTA update or AML burn package. Is there a chance you selected something other than the defaults in USB Burning Tool? If you choose the option to "overwrite key" that might have caused you to lose the factory settings.
Originally posted by SJMoore View PostI noticed after installing Magendanz's Rom, My Mac & Serial number have changed, will I have a problem using the OTA update in the future?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 3494 users online. 0 members and 3494 guests.
