MECOOL KM9 Android TV Voice Remote Amlogic S905X2 A8.1 4/32 Dual Wifi Fast lan BT4.1
Originally posted by Rakuga View PostI don't know what to say. Mine works normal. No issues with that Netflix mod. My tv is a 720put but i have the Mecool km9 configured at 1080p.
Enviado desde mi Mi A1 mediante Tapatalk
Originally posted by panchovilla View Post
Too buggy here. Even after I reset it again. This box is a headache .
Originally posted by Rakuga View PostI feel you bro. Maybe with a future update we will get a better box. Saw some comments on how the Mecool m8s pro l got some features, like drm support with a OTA update. Fingers crossed will be the same with our boxes.
I will find out......
Enviado desde mi Mi A1 mediante TapatalkMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by trebor View Post
They a Picture paints a Thousand words...in this its 4k worth (shhh don't tell anyone)MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I am afraid, that what we have is all we will get. If this box is missing some items, it will NEVER get them. I had great hopes for Mecool, but guess they will join the ranks of the rest of these mediocre Chinese boxes.
I have installed 5 or 6 apps directly from USB drive and didn't get any installation errors. Applied all the google updates and still have no issues installing apps from internal storage, USB Drive, Play store and Aptoide TV. Based on my usage so far the box runs stable and performs ok and in what it said it would do (for me only 1080p no HDR use case scenarios). 4K also should not be a problem at least based on specs. Since it supports Widevine L1 I am hopeful someone will get a forked version of Netflix to work in 4K soon. Skipping microsoft DRM is a bummer as I use Amazon prime. But as a work around for now I am using web version as a bookmark shortcut created using HALauncher.
Originally posted by panchovilla View PostI got HDR on Netflix. It shocked me.
M8S Pro L does HDR on Christmas Chronicles on Netflix as well.
If it indeed able to then its good news too
Originally posted by Rakuga View PostInstall this modified version of Netflix 3.2.2. made by Tork24. Search Google for it. You can't do Netflix 4k, but 1080p you can for sure.
I really hope Mecool will correct the several issues with the drm licencing. I rad an article that states installing 64bit apps in this s905x2 boxes is blocked due the many bugs you might found. I think that's the reason i couldn't install dolphin emu. Very sad because it may run a couple of good old games like New Super Mario.
There are currently 5984 users online. 1 members and 5983 guests.
