This ROM is based on the official Pipo firmware release dated 9/19/2013.
This firmware makes plenty of improvements over the previous releases in performance...and stability. I'm not much for benchmarks, but I got 17148 on the last ROM, this time it is up to 19565...a significant improvement, I would say.
Since this RileyROM v2.0, I decided to put a little more work into it than I've done with previous releases. I've tested the wifi version thoroughly and I haven't found any glitches yet.
v2.0a Features:
Full Root with SuperSU
Debloat
Reduced System.img file size with ext4 file system
The usual 2, 4, 6 or 8gb user app space parameter files
Your choice of stock recovery or CWM
Multi-user support (I finally got this to work correctly) You will see a new option called Users in settings.
Some Internet/Wifi tweaks to improve speed and streaming
Some video performance adjustments
A few general performance enhancements
The Petrus Reboot app
Disabled OTA updates
Brand new boot animation from Tattman65
tun.ko, cifs.ko and m4.ko installed
Download:
RileyROM v2.0a wifi
RileyROM v2.0a 3G
If this ROM makes a difference for you, please consider a donation to support future RileyROM's here at Freaktab.com Donate!!!
