Pipo M8 Pro RileyROM 2.0
    Now v2.0a
    I just finished uploading v2.0a!!!!!!
    This version has an expanded ext4 system.img file for more room to make your own changes if you are ballsy enough to do so.
    I added parameter files for 2, 4, 8 and 12gb user app space, this time.
    For additional OpenVPN support, I added some working tun.ko, cifs.ko and md4.ko modules...at least I hope they work for you.
    Just use the same links on post #1
    Enjoy!!!!!!!!!
    Randy
      Hi!
      Pipo_M8_Pro_wifi_RileyROM_2.0a.zip is corrupt!
        Originally posted by DINik View Post
        Hi!
        Cheers Riley for the update, just flashed and all seems well. Your the Man!
          Sorry replied in Quotes with error!
            Hi!
            Try downloading again. If it's still bad, I'll upload it again when I get home.
            Randy
            Randy
              Randy
              system.img: Invalid compressed data to be retrieved.
              Serious Error: invalid compressed data.
                Ok. Let me upload it again.
                Randy
                Randy
                  Where are you getting that error? Is it your unzip app...or the flash tool?
                  Randy
                    Unzip with WinZip 17.5
                      The original works fine on my laptop. I downloaded it to my desktop and got the same error. So, I'm uploading the original again to the server. I'll let you know when it's done.
                      Randy
                        OK, the upload is complete.
                        Download again and see if it works this time.
                        Randy
                          Thank! Archive unpacked successfully!
                            Great work riley! Was waiting for something new to flash Already was running smooth on 1.9 but improvements are always welcome
                              VPN
                              Hi
                              If I go settings-wireless.....-vpn i still get a blank screen. Am I doing something wrong?
                                I don't use VPN, so I can't test it. The modules I used were working on the M7 Pro tablet, which is very similar to the M8 Pro. That's something we will have to work on.
                                Have you tried using the apps from Google Play Store that install those modules? Maybe there is a problem with my insmod command in the boot.img file.
                                Randy
