[ROM] Mecool M8S Pro LB TVStock Nexus ROM (Android TV 7.1)
Some programs just refuse to run because "the box" is rooted. Is it possible to unroot?
Magendanz can you please provide a build of the rom without root? I've tried using SuperSU to do it without success
#153.1Guest commented25 May 2019, 17:56Editing a commentNo, I'm not going to make separate releases just to unroot. However, tillaz87 created a shell script to do this here: https://forum.freaktab.com/node/669422
Hey, today TV box stopped connecting to wifi. It won't even see it. Actually, it doesn't see any WiFi connection around. Yesterday I installed and app, but it didn't seem to have caused any conflict. I uninstalled just in case, but the problem persist. When I turn on the TV box, it used to connect automatically. Now, WiFi is set to off, and when I switch it on, it turns back to off after a minute. Any help, plz?
Originally posted by lux aeterna View PostHey, today TV box stopped connecting to wifi. It won't even see it. Actually, it doesn't see any WiFi connection around. Yesterday I installed and app, but it didn't seem to have caused any conflict. I uninstalled just in case, but the problem persist. When I turn on the TV box, it used to connect automatically. Now, WiFi is set to off, and when I switch it on, it turns back to off after a minute. Any help, plz?
I installed corelec with a wifi dongle, but I never found a dongle that would work with android. I tried most of the custom roms, but I gave up. If you are good at soldering, you could try replacing the aerial, but I'm not sure if it will work.
Network port still works.
Sorry for asking something that's certainly been asked before.
Got the M8S Pro L (B) and recently used the stock updater to install the Nano Nexus ROM. Everything was fine but decided I wasn't overkeen on the minimalist look and decided to go back to stock. HOW DO I DO THIS?
Tried using the BurnCard Maker. Did what I needed, put it in the box and it doesn't start recovery, just loads the box as normal. I don't have a USB cable to try and use the USB Burning Tool. Is there any other easy way that I can get back to stock? Can anyone point me to anything that I can follow?
Thanks if someone can help.
QUICK UPDATE..
Just tried it again. It flashed up with the droid and said upgrading. Stayed on the screen for about a second then changed to No Signal. Box now has blue light but no signal when I try to restart it again.
Is it goosed??
Hi, I bricked my m8s Pro LB and now only the blue light is on, but no signal through the HDMI port, so can't see anything on the screen.
Tried using USB Burning Tool (2.1.7.0) and fortunately the box is initially connecting successfully via USB, however I cannot find the correct ROM to push the package down to the box. Tried using OP's ROM .img and I keep getting this error at 2%:
[Err]--[0x10105004]Romcode/Initialize DDR/Read initialize status/Error result
Reading around, it seems I don't have the correct ROM for the LB and no one has an .IMG of the stock ROM, so I'm stuck.
I tried the SD CARD method, but the box won't recognize/boot from the card, and I can't load up TWRP because I can't see the boot screen (no output to HDMI).
Suggestions, or is this box toast?
Thanks!
Hey guys,
been using this Rom for a pretty while now and use it on couple of friends boxes too.
I wonder if there is a possibility to boot into TWRP after the first flash like button combo or something similar.
The way I do it now is flashing then Setup Wizard then installing Quick Reboot app from Chrome and Apkmirror.
Hey. We are using Mobdro no ATV version it is working fine on nexus ROM, I downloaded the App from https://apkpassion.com/mobdro-for-smart-tv/
I am using this for past 3 months and not having an issue. I don't know what will happen after the update. Thank you
Originally posted by Snakx View Post
in the magisk hide option:
hide root for all live tv and streamning providers apps
after i hide root for all google play apps (play store, game, movie)
(i can't see in my box now, my wife see netflix lol)
# reflash
- rom with burn cark maker or usb burning tool
- after flash go in TWRP get a factory reset
- flash cleansu.zip
now i cant access TWRP, am i missing something?
edit:turned off then repeat pressed menu on bootLast edited by logmarshall; 14 August 2019, 22:30.
You don't need to solder anything, buy one of these https://www.kenable.co.uk/en/usb-cables-adapters/usb-20-cables/6865-kenable-usb-20-a-to-a-male-to-male-high-speed-black-cable-15m-5ft-006865-5055383468652.html
Then use the USB Burning Tool from here https://www.mediafire.com/file/0s5q2...8_x86.rar/file
with this ROM https://forum.freaktab.com/forum/tv-...android-tv-7-1
Run the USB Burning Tool on the PC - Select the Language from the middle tab.
Do NOT power up the M8S media box, but rather plug a USB-A to USB-A cable from the M8S Pro L to the PC
Quickly press the Menu button on the Media Box's remote (3 bars button). Keep pressing until you see that there is a connection between the M8S and the USB Burning Tool under Device ID.
In the USB Burning Tool go to File >> Import image ... then press Start and wait until it is finished
I followed the above and mine is now working fine again.
There are currently 4851 users online. 2 members and 4849 guests.
