[ROM] Mecool M8S Pro LB TVStock Nexus ROM (Android TV 7.1)
Guest
Originally posted by mcastro View Post
Hello Guest
I'm using this ROM regularly from months.
It's very well done, great job and thank you.
But I'm facing a problem with the game Asphalt 9. In that game only my gamepads don't work. I have a chinese bluetooth controller that works pretty well in Android environement, in all other games, including Asphalt 8.
I tried too a Dualshock 3 paired with a 8bitdo adapter. It works perfectly in Real Racing 3 and in all the Android environment, but again it doesn't work in Asphalt 9. Do you think is an issue of Asphalt 9 or something in system files of gamepad?
Consider that the chinese Bluetooth controller works well in Asphalt 9 installed onto my Tablet Galaxy S2 SM T-719.
Thank you very much!
Guest
About the controller I gave up. The games that works, I play, the others I don't care!!
I have some questions about the two versions of the firmware (this one and the nano/stock variant):
Can I swicht from one to another without wiping the memory device? To leave all the apps where they are.
In nano/stock variant, Youtube is capable of streaming 4K videos? Or should I install the AndroidTV version of Youtube?
In nano/stock variant, Play Store is the same as mobile phones? So the apps are in mobile version?
What was this for?
Originally posted by Magendanz View PostYou should be able to use this: http://freaktab.org/f71c8eff3509cf37
Today I tried the ethernet connection and looks like it doesn't work.
Is it a known bug?
How could I investigate better?
Any logs needed? How to produce them?
EDIT:
Solved. It was the RJ45 plug not well inserted. I had to plug it really hard. Not really high quality port. I think I will put some piece of something to tight it well.Last edited by varma; 17 March 2020, 23:44.
Hi.
I have a MECOOL M8S PRO L Android TV With voice remote.
LB version.
I try nexus rom but I want to return to original android tv rom because in the nexus rom the voice remote doesn't work properly.
You have any ideas where I can find this rom?
I find only original firmware without android TV or custom rom.
I have to find the original dump of mecool android tv rom.
Thanks a lot
There are currently 4935 users online. 0 members and 4935 guests.
