[ROM] Mecool M8S Pro LB TVStock Nexus ROM (Android TV 7.1)
Hi Team,
So 2 days ago Netflix crapped out on this ROM. I keep getting a 5.7 error. I've reinstalled it and tried other builds but no luck. I have to run an older version of Netflix and its the mobile version, not the Android TV version. Very frustrating as the android tv version is better by far. Any ideas what's going on? Any suggestions for a fix?
Originally posted by san_ic View Postsorry, did not understand. I have my m8s connected to my laptop usb to usb. what next?- Download the Stock image for your model M8S Pro L to a Windows PC (Google it)
- Download and install the USB Burning Tool on your PC.
- Run the USB Burning Tool on the PC - Select the Language from the middle tab.
- Do NOT power up the M8S media box, but rather plug a USB-A to USB-A cable from the M8S Pro L to the PC
- Quickly press the Menu button on the Media Box's remote (3 bars button). Keep pressing until you see that there is a connection between the M8S and the USB Burning Tool under Device ID.
- In the USB Burning Tool go to File >> Import image ... then press Start and wait until it is finished.
Originally posted by corleone13000 View PostHello,
Thanks very much for this great rom I just installed !!
I now would like to use TWRP Manager, however once launched it did not detect any TWRP version. How come ?
Besides How can I access TWRP on the box ?
Thanks in advanceSorry for my badly english
Hi fgetkateAbout[ROM] Mecool M8S Pro LB TVStock Nexus ROM (Android TV 7.1)Did u sort your Netflix error? Is anybody else having problems running Netflix with this build? I having problem accessing Netflix, now getting error (-100) Anybody any Idea how to help sort this problem please?
Originally posted by kobra2 View PostHi fgetkateAbout[ROM] Mecool M8S Pro LB TVStock Nexus ROM (Android TV 7.1)Did u sort your Netflix error? Is anybody else having problems running Netflix with this build? I having problem accessing Netflix, now getting error (-100) Anybody any Idea how to help sort this problem please?Sorry for my badly english
Originally posted by Snakx View Post
google have banned the widevine L1 ID from mecool. how many app used this DRM are blocked. you can use the smartphone netflix app and with magisk + module "liboemcrypto. so disabler" but SD quality or/and magiskhide prop config module with mibox3 buil.prop infoHi Snakx, thanks for that information. I want to watch Netflix in 1080p at least, I have only just purchased this Mecool m8s pro lb box from Amazon & its still in the return window, so I could return it for a refund? Or do you expect there will be a patch for this problem anytime soon? Or any other workarounds?
If you want that, get a Jetstream 4K, Xiaomi Mi box or tv with built-in Netflix.
Take other box mi box S , NVIDIA Shield...
Envoy? de mon XT1562 en utilisant Tapatalk
You won't ever get any 1080p Netflix.
There are currently 2856 users online. 0 members and 2856 guests.
