[ROM] Mecool M8S Pro LB TVStock Nexus ROM (Android TV 7.1)
Hello , I hooked my (Mecool M8s Pro L) with a USB 3.0 (A) Male to (A) Male cord to my PC and the PC didn't recognize the Box. I even put a Loaded SD card inside the Box and rebooted the box and re-plugged it back into the PC and the PC didn't recognize the Box. How can I make the PC recognize my Android Box? Thank You
Well the WorldCup drivers should be installed when you install USB Burning Tool. To be recognized, however, you've got to hold down the reset button when connecting the USB cable. That's difficult on this box, since they removed the button. You can either crack the case and short the reset pins or just install a terminal window and type "reboot update" with the cable already connected to the USB OTG port.
san_ic ...correct the M8S has no reset button. To flash a M8S you have 2 options. The easiest is use the 'burn card maker'. 1) Convert Magendanz ROM (*.img) to a SD card and insert into the unit (connect hdmi but no power). Then on the remote control start pushing the button with the 3 stripes and reconnect power - upgrade will start automatically. 2) For USB Burning let the tv box boot up, connect the USB cable and then install and run any terminal emulator app. Once open, type 'reboot update' the burn tool will show 'connect success'.You can also push the same remote button above 'many' times till it connects.
Originally posted by Snakx View Post
i can't now. you can flash with usb burning tool or sd card maker
Thanks Magendanz to provide this TVStock Nexus ROM for LB variant finally.
I have been updated the stock ROM to TVStock Nexus ROM today.
Just download the rom image file and flash the device by using the Burn_Card_Maker utility.
Everything works fine, expect the home screen app icon seems to become smaller than stock ROM. (6 app icons became 9 app icons per row in home screen)
Anyone knows how to adjust the app icon size? my TV resolution is 1080p.
Originally posted by iamchjl View PostThanks Magendanz to provide this TVStock Nexus ROM for LB variant finally.
Can anyone guide me how to flash back to stock rom by using TWRP or burn card maker ?You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by FelipeFlaBR View Post
I only used burn_card_maker utility to flash rom file, and it works to flash Magendanz's TVStock Nexus ROM.
Not sure why I can not flash back the stock rom using the same way.
I have confirmed the erase_bootloader option is toggled in burn_card_maker utility.
Anyone who can let me know because i?m new whats the difference between this modded rom and normal stock?
i have M8S Pro L (LB version with voice remote) and using stock rom, which is android tv based.
So how does this differ, because the pictures in this post look pretty much the same as stock. Is it faster, or does it have less bloatware, or more customisable maybe?
Magendanz: I cannot thank you enough. I bricked my M8S but thanks to your efforts, I was able to bring it back to life with USB Burning Tool and your Stock TV Rom and then the OTA Update, thereby getting rid of the clumsy Stock ROM. The secret I didn't understand was that when using the USB Burning Tool, turn the power to the M8S Pro L to OFF. I am sure others have stumbled into that error.Last edited by Mainspring729; 23 November 2018, 04:08.
Can anyone explain how to change the login settings for Netflix on the Gapps OTA Update? Darned if I can see how to get my username/password into this app.
[SOLVED]Last edited by Mainspring729; 24 January 2019, 01:47.
There are currently 28244 users online. 1 members and 28243 guests.
