M8s pro W Firmware...
[ROM][OEM] Mecool M8S Plus W (Android TV) by VideoStrong
Originally posted by soldiaz View PostAnyone tried wired generic USB Gamepad?
Like this one: https://m.tomtop.com/p-f1786-2.html
Hello Novato,
Could U help me?
I just bought mecool M8S PRO W and when I'm traying to install anroid tv by nexus I have an error tat I can't install this packed over the newer build.
I download rom from yor post but I can't edit it with es file mennager. Could U tell me how to do it? Or meybe i another way to do it.
i own a m8s pro w and i had an issue after flashing this rom.
the first boot went ok but after a subsequent restart, i get the screen of the green droid with a red circle and X in it.
the same happens when i try entering recovery.
how do i get my box back to default since recovery does not work as well?
Originally posted by krwlng View Posti own a m8s pro w and i had an issue after flashing this rom.
Originally posted by Novato View Post
The same octre with me, is affecting everyone. This is my nephew's M8S Pro too.
Originally posted by uscool View Post
I get Network error when trying to open Netflix
Regards,
FredrikMK809III RK3188-T AP6210 running Neomode 3.1
Originally posted by Fredrik View Post
Same here. When I start Netflix i get Error code (-100) and it says that it can connect to Netflix. I use cable ethernet and I know that I have internet access. Any id?as?
Regards,
Fredrik
You can try to delete /system/lib/liboemcrypto.so file then you can use the phone Netflix app with 480p quality.
There are currently 1701 users online. 1 members and 1700 guests.
