Any help plz ? or any other method ? tried a lot theses last days with no result
[ROM][OEM] Mecool M8S Plus W (Android TV) by VideoStrong
Is it possible to cast (Chromecats, Miracast or any other cast) the screen from a phone or tablet to Mecool m8s pro w (converted to Mecool m8s plus using post 1 in this thread)?
I am able to cast pictures but not the whole screen. I have my mecool connected with ethernet cabel to router and phone connected with wifi to the same LAN, is this a problem for cast? Does it have to be wifi on both the mecool and the phone/tablet?
Regards,
FredrikMK809III RK3188-T AP6210 running Neomode 3.1
Originally posted by Novato View PostIn the spirit of the Pure Nexus Project, these TVStock Nexus ROMs deliver the pure Android TV experience using the Open GApps TVStock Package. The goal is to keep true to Google's vision and use the bare minimum of OEM or third-party apps or add-ons, which can be added.
Note: This is the official Mecool M8S Pro W 2.4 (Android TV version). Do not attempt to install it if your device is the non-Android version of Mecool M8S Pro W, this will cause problems for your device. Try the procedure below only if your device is the M8S Plus W. Neither I nor the freaktabs forum are liable for any damage to your device. That said good luck, and let's go.
How to make it? Very simple, next a little tutorial:- Download the M8S Pro W ATV OEM Firmware here.
- Using Es File Explore modify target Version Date (below).
- Put the firmware on the USB stick, connect to the box.
- Go to the UPDATE app, open and choose local update
- Choose firmware.zip from the root of the your pendrive.
- Check Wipe Data and Wipe Media, data will be cleaned.
- Press confirm and wait for the update to complete
Go to system/build.prop, find the line "ro.buid.figerprint=Amlogic/p21x/p21x:7.1.2/NHG47L/20180523.122853.V0213:userdebug/". Change date '20180523' to '20180223' and save the change. Go to root/default.prop and repeat the same procedure above in /default.prop on last line:
On my device Wi-Fi did not start so I had to make another change in the build.prop
- Go to /data/misc/wifi/ now delete wpa_supplication.conf and NetworkHistory.txt.
- Shutdown your device and wait 20 minutes, turn on and connect on your wifi again.
Especial thanks for: Guest Marcelo Filgueira and sappy
First of all thank you on this work, I was able to unbrick a M8S Pro W (REV 2.2 / blue board...)
I have a question. You said you experience issues with the Wifi "On my device Wi-Fi did not start so I had to make another change in the build.prop". I am having the same issue What exactly did you modify in the build.prop?
Thank you.
Originally posted by soldiaz View Postalright, i'll try!
For now short tutorial howto change shitty M8s Plus W --> Mecool M8s pro W:
Needed stuff:
https://www54.zippyshare.com/v/4MfTg829/file.html (Tools.zip)
https://drive.google.com/file/d/1ZKu...p6S74nW5R/view (Target firmware thanks Novato )
Let's change...
2. Extract fw and tools
3. Get recovery.img from M8sPro W dir and put on USB Stick along with flashify and M8sPro W update.zip
4. Bootup device
5. Install flashify
6. Start flashify and select Flash recovery. Then choose file recovery.img from USB Stick and flash
7. Install powermenu.apk and launch, select reboot recovery
8. In Recovery select update.zip from USB stick
9. Wipe cache, factory reset
10. Boot to system. BE ON REAL ATV
That is all, no editing or sth else
There are currently 4465 users online. 2 members and 4463 guests.
