Introduction
Welcome to the Poison ROM thread.
As promised, im delivering a stunning quality ROM to the S905x2 community
Alot of time and effort has been put into this project so if you feel the ROM is good enough for a donation, you can DONATE HERE
This rom was originally created for the Beelink GT1 Mini, its an EXTREMELY powerful and snappy device, if you dont have one and want one you can buy one HERE
Features
Network Tweaks
-Disabled logging and sending data
-Use googles DNS by default
-Extended TCP buffer size
-IPV4 tweaks
-Other various network enhancement tweaks
UI Tweaks
-Semi transparent navigation and statusbar
-Changed the launcher background
-Better looking tile icons
-Transparent tiles
-Better looking application icons
-Poison boot logo
-Window animation scales 75% faster
Property tweaks
-ADB enabled by default
-Device does not sleep by default unless power key is pressed
-Auto change language disabled by default
-Faster streaming(network tweaks)
-Better image quality
-Enabled performance tuning
-Enabled dithering
Fixes
-Statusbar and navigation bar non persistant
-PPPoE non persistant(Massive memory gain)
Smoother experience
-Removed bloat apps
-Removed bloat libraries
-Removed factory apps
-Removed all pre-installed apps
-Removed obsolete/unusabled apps
-Remove TTS data(not compatible with device anyway?)
-Adblocking hosts
-Init.d enabled
-Added smoother graphics tweaks
-Netflix HD preinstalled(removable)
-EsFileExplorer as default filemanager
-OTA updates
-Strict LMK handling
-Deadline scheduler set on boot
-SDcard readahead increased
-Disabled certain logging
-Root and system mounted Noatime
Universal installation
... Plus more ive forgot?
Installation
Requirements - USB male to male cable and a PC.
1. Download USB burning tool 2.1.7.0 specially made for S905x2 devices and install - USB Burning Tool 2.1.7.0
2. Open USB burning tool and click "File" at the top left of the program
2. Click import image then select the Poison_S905x2_V1.0.img file
4. After the firmware had loaded click the "Start" button on the program
5. Remove all USB's and anything plugged into your device
6. Connect one side of the Male to Male USB cable to the USB 2.0 port of your device and the other to a USB port of your PC.
7. Wait until the progress bar reaches 100%, then click the "Stop" button and reconnect your device to your TV.
8. Enjoy POISON.
Download
Download V2.0
Changelog
V1.0 initial release
