[S905x2 devices] Poison Rom [V2.0] [Android 8.1.0]
Originally posted by [email protected] View Post
Originally posted by romcrazy View Post
You can use the Amlogic customization tool to unpack the img and take out the launcher apk in system/app folder, which can be normally installed by side loading. If you can wait a day I will take the launcher out and post here. Please dont be salty, the playstore for this rom doesn't work for h96 max x2 also, but everything else worked on testing. Its a very solid rom, just the play store has some issue. If you want only the launcher I will get that for you.
Thank you I would really appreciate that!
I am trying to do it myself it says do not detect jdk environment can you guide me alittle
OK so I figuered it all out but the APK wont install any idea what I might have to do to make this work?
PLEASE be cautious, replacing stock launcher with different launcher (if it doesn't work) will cause errors and boot problems, so before trying this, you must know how to flash firmwares. (So that you can undo this).
I have extracted an apk from the rom, I will try to install in on my box today. I think direct apk side loading wont work. It will end with "apk not installed". What I will try is, I will replace the stock launcher apk with this apk, keep the same name and same permissions. And on reboot, new launcher should get accepted. Atleast in theory.
Thanks I appreciate it..... .. I flashing ROMs as often as I tie my shoes it's not a problem I tried to figure it out but I end up with the app not installed I was nervous about replacing the home launcher.. .... One time I ended up with a black screen because I had no launcher luckily I figured figured way out of it... ... see the first time I played with the customization tool I got to start learning how to use that. .... thanks again
just install the apk....tested and works for me...
Originally posted by kenduvernay View Post
This hasn't worked since the day it was posted. Plenty of users wonder the same. But look at the OP, Moderator - [AMLogic God] Guess if you're a [AMLogic God] it doesn't matter of your stuff works.
So as im not contracted, nor do i work for someone, theres no ETA or due date, but i can assure everyone although im not very active this project is far from finished, my team plans on release a range of firmwares for all devices(S905w, S905x, S912, S905x2 and S905y2) with both AMLogic based UI and ATV based UI
Also, for anyone who needs it, USB burning tool 2.1.7.0 - https://mega.nz/#!WJ8hSK4Q!pRz4veH_J...u5mPDG-5X01ECU
This rom has TWRP integrated? If yes, which version?
and one more question for ricky divjakovski :
is there any chance that we get also a poison rom for S905w devices, for example my A95X? Or perhaps this 905x2 rom also works for my A95X (S905W-device)???Last edited by tombraga; 08 April 2019, 08:31.
There are currently 2441 users online. 1 members and 2440 guests.
