Tanix TX5 Max Amlogic 905X2 4/32gb Dual Wifi Lan BT4
New Firmware out. Anybody has an idea of the changes/bug fix?Last edited by PC_Pal68; 20 February 2019, 01:16.
Thank you for the link, but that wasn't the question. I was wondering if someone knew what the changes were. Saw a few links for the firmware all over the web, but no one seams to know what's new.
Guest Now I get confused haha. Are there actually 2 firmware releases or is you link just a different, probably much faster, download link?
I linked to the one that was posted today on CGR (https://chinagadgetsreviews.com/firmwares), but it looks like it's just the 20181226 release that Trebor posted earlier.
https://mega.nz/#!CGhEkQiT!tPM8FQ-FA...-eWcRc-nhJ0qhs
Found this link on 4pda. Russian buddies have done a very good job by adding Navigation bar and Notifications curtain
[QUOT"....[/QUOTE]....Other changes are
Well, for my part, this is the result of night work.
We sew on the original official.
If if someone has not had time to sew on any then there is no need for boxing firmware.
Install the box on the terminal, go in the terminal, write reboot update.
Boxing comes in stock recovery.
Next, through the mounted Recovery install UPDATE_PTCH_TANIX_TX5_MAX.ZIP
X96Max (S905X2) [Android] (Post Vasily_5 # 79867668)
That we get the firmware. Working hours, WiFi, Bluetooth, Remote. Russian language, Time zone Moscow Europe +3
Patch for boxing.
Kernel kernel patch. kernel support init.d.
Fix init.d.
Fix GPU frequency increased by 846Hz. That improves the work of graphics.
Fix Sleep Sleep Mod.
Fix the Temp folder in the system.
Fix Bightness.
Fix immersive Statusbar.
Fix module amvdec_h264
Fix parameters nr10bit_surpport.
Fix build.prop Vendor and System. To support the mode 2160p 60 4k Video.
Added original wallpaper.
The system has already nested Libamcodec.so, Public libraries.txt is also spelled out.
Added programs:
ACE Stream Media. Fix autostart.
AdAway ad blocker.
File Manager. With the ability to connect to SATA, FTP, DLNA, WIFI, transfer files and install APK files from your computer.
Root Explorer. TorrServce.
At the request of the Workers Power VPN program, the substitution of IP address.
KD Player aka Kodi 18.0 + Installed SPMC 16.7.4
HD videobox MOD program does not require updating.
TTV Player with sewn playlists.
Additional Play Market "Yalpstore" the ability to download apk.
+ Another Launcher Square Home +2. The ability to drag and drop shortcuts on the desktop as well as the configuration on your own.
AirPin Pro. to connect the output to the TV image from a mobile device..................
I installed the patch..works great... Has working navigatin bar and notification curtains
I just flashed the zip after wiping cache, dalvik, data
Note the work has been done by Vasily credit goes to Russian guys.
DISCLAIMER
& yes whatever we do its totally at our own risk and peril. u brick ur box its ur paperweight ur workLast edited by usernamereg; 20 February 2019, 16:18.
Got myself two of them.
One is working fine, the other not.
It keeps "freezing"/lagging every now and then and you actually have no use for it.
Temps seems ok and i had the same behaviour with the wifi turned off and the lan cable disconnected.
I just downloaded the fw update in case a miracle happens (also tried factory reset). Can someone post the update procedure please?
I am reffering to the official fw, not the Russian one (is the procedure the same?).
Attention! Box is locked by the manufacturer! Before you do something, think carefully. Do not take any action without prior backup !
Download firmware from (zip file OTA update)
https://mega.nz/#F!QApmFKSI!P6a0ktL0...X7uCg!hEowxQxI
Download Flashify from playstore, the box is generally already rooted so download and flash TWRP image after >placing TWRP img in sd card and >>choose to flash from storage using img file option (TWRP img is in above link too but blurry) prefer img below
https://4pda.ru/forum/index.php?show...#entry82017372 (u will have to register and login)post #221)
Restart the box and immediately pressing menu button rapidly...u shd boot in TWRp Recovery or use rebooter app
Use TWRP
Backup the ROM
Then flash the ZIP file with latest Firmware downloaded above ZIP file ota update
To get navigation bar you have to flash the update patch by Vasily_5
whatever we do its totally at our own risk and peril. u brick ur box its ur paperweight ur workLast edited by usernamereg; 22 February 2019, 06:05.
Hi there usernamereg
Thanks for the help and the links
Were you able to install the update patch through the stock recovery, or did you updated through TWRP?
It seems the TWRP link is no longer working, i get a 404 error. (also couldn't register because of the "type this" part... it's russian)
i tried updating the patch through the stock recovery update, but it's not working . I get a signature verification error (error 2 )
Tried a TWRP for the X96 max, also get signature verification error.
So , i'm still stuck with no status bar no navigation bar
Edit :
Meanwhile i found a TWRP for U211 boards (X96 MAX ; GT1 mini) but it also worked on my TX5 Max
All is up and running now ^_^
Both bars are working and there are some new interesting apps , i just need to brush up my Russian language knowledge (wich is zero) to change them to english.
If someone is having the same problem as i was , loading TWRP. Here's the link :
Store photos and docs online. Access them from any PC, Mac or phone. Create and work together on Word, Excel or PowerPoint documents.
Originally posted by trebor View PostHas the Q/Enter Issue for us keyboard users luckily an easy fix.
Originally posted by thucnguyenit35 View PostHi, anyone have ATV firmware for TX5 Max S905x2?
But this version works very good on it. Only thing not working is Bluetooth.
So it's Android Tv time. It's a frankenfirmware, so there is not a clear base, i adapted it to X96 Max and GT1 Mini devices but it shoud run on many other device based on U211 motherboard so S905X2. Probably if it's not clearly meant for your device you'll have to change the remote config file in vendor/etc., and you'll get
Originally posted by TheBlackening View Post
also has anyone tried this one :- TanixTX5Мах-Volksware v.0.2.0_by_Sasvlad
Firmware exclusively for video gourmands, since amcodec and deinterlacing work here.
based on the latest X96Max core, BeeLink 115N0 firmware and Tanix stock at
HTML Code:https://4pda.ru/forum/index.php?showtopic=937559&view=findpost&p=82417151
HTML Code:https://mega.nz/#!KxsFhKpD!0iIxrBT2X5-rnMNOkRk9J2OUqw98NwIlorCA0shTMX8
There are currently 1953 users online. 0 members and 1953 guests.
