Tanix TX5 Max Amlogic 905X2 4/32gb Dual Wifi Lan BT4
Originally posted by trebor View PostYep I did not go looking to hard at the time
One app i was running while testing it was like a game of peek a boo it was in and out every few seconds crazy...all under control
Resistor goodness that sound like work, bit of black tape or the inside much quicker
#93.105-02-2019, 07:42Editing a commentWell you need to see what I was making a comment about....to put it in context
trebor?The side way pop out should disappear when you disable playstore notifications I presume, and wouldn't it be possible to dim the display with adding a resistor to the power source?
My reply:
Yep I did not go looking to hard at the time:
One app i was running while testing it was like a game of peek a boo it was in and out every few seconds crazy...all under control?
Notification was in and out like a game of?
"This device is not activated yet, please contact your vendor! Device will reboot in 30 minutes"
Try this,
https://4pda.ru/forum/index.php?show...ost&p=82266882
I used google translate for ur convenience below, if it dont work out....ping in this thread ill try to write all steps this week end in english
How to restore mac and deviceid (this is not an android, this one that is visible through cat / proc / cmdline) if you somehow lost the
mac on the board, box, box, there is no deviceid anywhere and you can generate it later.
To generate your deviceid, do the following:
Open the site https://ideone.com , remove the default code and insert the following - tyts or from thetanixtx5maxdeviceidgen.txt file (10.39 KB)
(no difference, this is the same thing)
Important note, mac use as 90: 0e: b3: 02: 39: af , but not as 90: 0E: B3: 02: 39: AF
Deviceid will be different - 5d3ef6b2 and 581c5d41 in the second case
Insert the contents into the window. In line 262 (almost at the end) we change to
System.out.println (new SyncTask (). Sync ("01: 01: 03: 04: 05: 06"). Substring (0, 8) .toLowerCase ());
01: 01: 03: 04: 05: 06 on your poppy.
Click Run , wait for it to be executed, shake to the bottom of the page and see your deviceid under stdout .
How to flash mac / deviceid:
For someone who has a uart cable, it's easier for uart to boot, and write
(data, respectively, write your own)
keyman write mac str 01: 01: 03: 04: 05: 06
keyman write deviceid str e81b9de1
Everything is flashed, reboot and rejoice.
For UBT firmware, do the following:
Download the archive and unpack it.license.zip (1.5 MB)
We put the deviceid.ini and mac_ether.ini files in the C: \ Program Files (x86) \ Amlogic \ USB_Burning_Tool \ license \ license folder
and open them and edit them
in deviceid.ini
deviceid = e81b9de1 to your
in mac_ether.ini we change
start = own_mac
end = own_mak_just only at the end for example ff
current = own_mak
used = 0 <--- you need 0, then the first one from the list will be used
Example
It is important to edit files before running UBT, otherwise changes to the files will not take effect.
Run UBT, select the file TX5MAX_key.img and remove and mark as shown in the screenshot.
Remove - erase flash and erase bootloader otherwise the firmware will be erased
We note what needs to be sewn, in this example, mac and deviceid
Click Start and after a few seconds everything will be flashed (the firmware will not be erased).
Reboot and enjoy.
If anyone is interested, Java code was taken from the original firmware from apk Deviceinfo - com.oranth.deviceinfo
Post has been editedasasvlad - 11.02.19, 01:59
Originally posted by chenrp View Postany android 9 for this box?
http://4pda.ru/forum/index.php?showt...ost&p=85534426
Originally posted by Sasvlad View Post
Originally posted by bajann View Post
Friend that firmwere android 9 is not stable or something missing?what about codec - deinterlacing works?
I used google translate for ur convenience below, if it dont work out....ping in this thread ill try to write all steps this week end in englishLast edited by xmannamviet; 08-04-2019, 10:25.
There are currently 1030 users online. 12 members and 1018 guests.
Most users ever online was 7,737 at 14:33 on 01-16-2020.
